Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Today I had a small crash with 3.3 RC3+: Before landing accidently I switched to drift mode. After landing I want to disam via yaw stick but the copter flipped on the ground. I think it should be possible to disarm the copter in every flight mode. I know thats stupid to land in drift mode, but when done disarming should be possible.
Cheers Gregor
I also happened with 3.3 rc1.
Looking forward to RC4 Best guess on when it will be available?
Randy is going to be trying for Sunday.
To all the developers,
will the "follow me" mode be smarter on the succeeding builds? I would love to see it perform better in follow me mode, like filming you from behind, or from your side. I think as of now, it is limited to fly above you.
just sharing my opinion. :) thanks again!
We are continuing to improve the performance of the follow me controllers. As Randy says, the rest is done from the ground station.
That is great. Which gps ( and link to the laptop running mission planner ) is recommended on the "me" side?
Thank you
Henri
Note to self: google USB GPS and there are the answers...
wiki follow me
Erwin,
you know we don't actually have a 'follow-me' feature in copter. It's all just done with guided mode's position or velocity controllers. We could add a follow-me mode but another option is for the GCS developers to do it... and I think tower supports all kinds of things like orbit and "lead-me"... I think.. I haven't tried it myself..
401
402
403
404
405
of 449 Next
