Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Emin,
No need to re-do the accel calibration unless you're upgrading from AC3.2.1 (or earlier). The "whiskers" problem was just a timing software thing that didn't invalidate any config.
Hey guys, thanks for all the great work getting to rc4. Looking forward to trying the autotune and ff changes. One question about the increased serial ports - does this mean more mavlink over serial? So can we move telemetry or gimbal now to the serial ports? I think I remember Randy saying the storm32 is currently hardcoded to the secondary telemetry port, is there a way to change that?
Fnoop,
Yes, it means that you could plug a telemetry radio into Serial 4/5 (which is normally the 2nd GPS port). This is part of the SToRM32 stuff in that Luis (and a few others) complained that they didn't have enough serial ports once they needed another for the gimbal. The SToRM32 gimbal can sadly only be used on Telem2 but I hope to make it auto-detect which serial port before AC3.3 goes live (that's one of the last changes that will go in).
Thanks Randy, this is so cool as us gadget junkies can now attach more gadgets at once :)
There is a bit of a problem with the recommended settings for the storm32 gimbal in that it identifies as a separate system (systemid 71) which confuses things like the popular teensy/frsky telemetry option which goes bananas switching between different flight modes of the two systems, and apmplanner2 although you can at least switch systems through that interface. But not sure if this is an issue that should be sorted at the 'client' end, ie. should the telemetry filter/listen only to the system it wants to hear, or the 'server' end, ie. should the storm32 identify as a component of the existing pixhawk system or can mavlink routing restrict which telemetry ports the storm32 signal can go out of.
Out of interest, will serial5 eventually be available as well or is there a technical limit on the amount of mavlink channels that could be used?
Tried loading the Beta version today but it failed with error: could not download the hexfile.
Trying again and the comport on my PC show up for a second when I connect the Pixhawk.
On the Pixhawk the LED is solid white and this seems not normal.
Feels like the board not activates the comport.
Suggestions? corrupt bootloader?
Found the problem, for some rason the sd card had to be formated. Did the firmware upload set the sd card as unformatted?
Goran,
The firmware shouldn't have caused that to happen although AC3.3 does have some extra logic to automatically format the card if it finds it's unusable for some reason. This has the effect of clearing all your log files but it doesn't get rid of parameters.
OK thanks, but the only way to access the pix with usb was to take the card out and format it in my PC.
Anyway it is fixed now.
Part of this is cross posted from here http://diydrones.com/profiles/blogs/u-blox-m8n-ground-planes-antenn...
I was flying on the shores of Lake Huron in Michigan today; absolutely gorgeous weather and flying conditions.
How do scenarios like this affect the barometer? Once the copter takes off, does the barometer "see" this altitude change? Would lidar be a good addition to have in order to get a true altitude reading once launching from the cliffs? Today was a practice flight for a trip this summer to PIctured Rocks on Lake Superior in da U.P. where I want to get some nice video of from above the water. I find it difficult to judge how far above the water the copter is and wonder if the barometer provides an accurate altitude so my equipment doesn't end up in the drink.
Thanks, I'm looking into LidarLite.
I still don't understand how there can be such drastic altitude errors when using RTL/Land (by switch or Auto mission) in only a few minutes of flying. It happens at my home, field and yesterday at the lake and two different copters, one using Pixhawk, the other AUAV-X2.
400
401
402
403
404
of 449 Next
