Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Haha as it happens the same although mine are version 2 which I believe are not flashed with simonK, I am thinking of changing them out as I have the version 1 on my fun machine and I'm sure they make for smoother motor performance
PhillNZ,
Thanks for testing. For the gimbal could you set the MOUNT_TYPE to "1" and reboot the board? That should get it working again.
Hi Randy, I did this yesterday as per your advise to my previous post and it didn't solve this issue.
Although the Gimbal LED is now showing that it is connected to the pixhawk (flashing blue not steady blue) any other ideas?
thanks
phill
All right, being fueled by so many great responses on AC3.3 autotune, I decide to give it a try last nigh on one of my machines. It is a large-ish (750 size) tricopter running on 6s lipo. Took off the gimbal, put a dummy weight in its place, made sure nothing is able to move on the air-frame and went to the park to do the autotune. I can say that the values autotune returned on pitch and roll are definitely not ideal, but certainly flyable, on the other hand yaw is a total miss, much delayed reaction + big overshoot. Need to say that the last firmware which gave good PIDs for any tricopter was 3.1.5, is there any way to take the best from 3.1.5 into 3.3?
Thank you!
edit: here is the link to the log https://drive.google.com/open?id=0ByNP743-FSrrd2ZaVjNxLXRqdzQ&a...
Hi Artem,
Could you provide some logs and a couple of photos of your tri.
I have not tested auto-tune on tri's but I am about to build one so any feedback you can give would be great.
here are the pictures: http://www.rcgroups.com/forums/showpost.php?p=30895667&postcoun...
the ****hawk is replaced now with AUAV-X2
Hi Artem,
Yeh, sorry about how long it has taken me to build a tri. I have ordered another one that should be pretty similar to yours without the gimbal. The frame I had was going to be a pain in the .... to mount the pixhawk on and the tail servo arrangement sucked.
The tune you supplied looks good for roll and pitch. I suspect that a big part of your problem is you have RCFeel set to 100. I would suggest dropping it to 25 or 50.
On the yaw tune. Again Autotune looked like it did an ok job of it. However it wasn't designed to handle tri's. When the cg of the rear motor is higher than the pivot point the copter rotates slightly in the wrong direction before starting to rotate in the correct direction. I haven't tried to approach this problem yet.
Could you give me an example of your yaw tune with parameters you think are good vs the ones from your last tune.
Thanks!
HI leaonardt, thank you for looking into this. You might remember we already spoke couple of time regarding autotune on tricopters. Couple questions, do you need some of the regular logs as well, or only those with autotune?
I will reattach the 3.3 rc4 autotune log here.
edit: and last 3.2.1 atotune as well
2015-05-20 18-47-20.7z
2015-05-20 14-10-58.zip
A couple more tests on the bench.
As suspected, once the unit warms up, a power reset shows less altitude deviation, it only climbs to about a meter in a couple of minutes and stabilizes. But it doesn't reset on ARM.
I had this happen a few weeks ago on a new DIY Pixhawk quad build running 3.2.1. Was causing false altitude reports and RTL did not climb to min altitude before starting the return flight. Had a few RTLs at 6 feet altitude. Fortunately was in testing mode so NHNF. Ran the MP Terminal Baro test several times and it clearly showed the altitude drift. Thought it was a bad barometer module so I contacted 3DR for a warranty replacement. They asked that I send the log files which they analyzed and reported back that the log files showed that all was well. Did not see in the logs what I and my friend who was there observed. The tech (who was very nice and supportive) asked for a video of the reported behavior along with the log file. Went to the field to make the video but when I triggered RTL, all worked properly. Made three attempts without "bad" altitude behavior. Strange but true. It's been working fine ever sense. I guess 'Quadcopter heal thyself" is a hidden flight mode we didn't know about :>)
