Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Whould it be possible to add a small delay, when Pixhawk is expecting new firmware, before it proceed to wake-up?
The problem I have is a competition between the laptop recognizing the USB and Pixhawk booting up. Sometimes it requires many attempts to flash new firmware with Mission Planner.
The stationary, also running Windows 7 Pro 64-bit, recognizes USB quicker and usually manages to flash.
I guess I'm not the only one having this kind of problem.
Anders
Are you using Mission Planner in A virtual machine?
No! This happens every time I try to upload new firmware to my copter, or any other Pixhawk.
No, your not alone on that. Sometimes I've used the reset button on the Pixhawk to get around this instead of yanking the USB cable out and back in (IIRC) ...
Perhaps this has been already mentioned but I haven't seen it.
Testing 3.3 RC5: The old TRIM_THROTTLE value which i used to copy in THR_MID isn't available in 3.3 RC5.
The THR_MID stay at 500. Was wondering which parameter replaced TRIM_THROTTLE?
Thank you in advance.
Henri
Hi Henri,
We found there was three parameters when their only needed to be one. So to answer you question, Thr_Mid is what you set to your hover throttle.
Hi Leonard,
TRIM_THROTTLE was set by FC, so all we had to do was hover for a while, land and set THR_MID to the value found in TRIM_THROTTLE. Simple, easy. and precise.
Now we have to look in the logs and approximate the value from the log.
I miss the old way too.
@Leonard: Actually when changing payload it was easy to check if TRIM_THROTTLE had changed a bit or more.. Just a little hover and it was possible to adjust THR_MID.
Actually it could be done automatically by the FC? (Or is there hidden trap?)
Henri
Hi Henri,
Sorry I lost your reply. I hadn't thought of that as I am always looking through logs. I would personally be happy with doing it automatically. Randy has been careful and kept fixed. We will probably automate it on the next release after a good amount of testing to make sure it is safe.
Sorry for the inconvenience. I will talk to Randy about it.
Already fixed here https://github.com/diydrones/ardupilot/commit/17063792cb0408076f3d7...
358
359
360
361
362
of 449 Next
