Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
make sure you setup your voltage/current meter in the PM. very often Chinese PMs have different scale than 3DR ones, I remember to get the correct current measurements with one such meter I had to increase the amp/volt to 21.5. On the other hand, I actually had to drop volt/volt a bit, otherwise it would show lower voltage than all of my voltage meters and a multi-meter, maybe in your case you should bump it up a bit? Anyways, I suggest first checking if you've setup your f/s correctly, than see if the volts measured with a multimeter are the same as reported by them mission planner connected via USB.
I had to increase the amp/volt to 20.488 for my 3DR PM to get accurate current measurements, so it's not limited to Chinese versions.
Nathaniel ~KD2DEY
voltage is reported correctly in MP, taranis via teensy and minimOSD and matches my multimeter precisely.
Not sure what is the deal...
I believe it has to be at or below the specified amount for a few seconds it does not go into FS immedialtly could that be the reason?
To be honest i am undecided if i even want that feature or not. It is not a priority, just an oddity. I am much more concerned about controls direction flip in a super simple mode as it is critical for aero photography and i cannot figure out what triggers that.
In case people are wondering where we are with the release, we've hit a number of unexpected issues over the past couple of weeks including:
1. the EKF's altitude estimate is not tracking the barometer correctly.
2. the trad heli is losing altitude when switching modes (Rob can correct me if I've got that wrong)
Once we get at least #1 sorted (and Tridge, Paul, Leonard are getting close) then we will push out a new release candidate. #1 isn't a crash-o-matic bug (as Rob would say) but it does lead to altitude hold performance which is not as good as AC3.2.1 especially in cases where there are high vibrations on the copter.
thanks randy and all the dev team for you hard working !!!
i think you are right, before to launch official 3,3, all stange issue should be resolve so it s not an easy way
MP says your log is corrupted. You might want to get it straight off the sdcard instead of using mavlink. I couldn't really look at it because of this.
I did see that it says you are using 3.4-dev instead of 3.3rc5?
So you haven't even armed at this point right? As far as I can tell the check should never trigger if the motors are armed. Do you still get it if you plug in the USB cable?
Log looks totally normal to me.
336
337
338
339
340
of 449 Next
