Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Another question: What do you think about reducing the RC_Speed?
      • Hi Leonardt,
        thanks for the quick reply! The vibrations came from the motors/escs. I´d like to reduce the vibrations before making another autotune.I thought it was better with low PWM setting but you say no.So I will reconfigure the blheli escs again tomorrow. Can you please give me a hint how to visualize these vibrations?
        3702704300?profile=original
        Or did you mean the spikes within one second?
        Cheers
        Gregor
  • Completed auto-tune (pitch/roll) today and ended up with 0 P values. Did I do something incorrectly?
    2015-06-14 10-23-30.zip
      Hi Robert,
      Sorry for the late reply.
      The results of your autotune are:
      Roll Rate P = 0.226
      Roll Rate I = 0.226
      Roll Rate D = 0.012
      Roll Stab P = 14.4
      Pitch Rate P = 0.508
      Pitch Rate I = 0.508
      Pitch Rate D = 0.021
      Pitch Stab P = 11.25
      So I don't see how a zero got added to your tune. Which values have zero in them?
      • Thanks Leonard, I even more confused now. I believe I saved the tune parameters and when checked on MP (both tuning and full parameter list I got 0 values after several refresh. After your response connected again now I can see different P values (0.163 both roll and pitch P) that does not match with the tune result either... furthermore, is not RATE_PIT_P and RATE_ROL_P limited to 0.3 max ? .. so Pitch Rate P = 0.508 ? In your list above both RLL and PIT P and I has the same value too.
    • Sorry, again - shall I keep the 0 P values after autotune as normal or autotune resulted in incorrect settings?
  • @leonard
      Were you able to take a look at my Auto Tune logs from this discussion?
    http://diydrones.com/xn/detail/705844:Comment:2018277
    Not to sound impatient, but I won't take it up again the way it is.
    Thanks.
  • Hi dev, I have been following the dev. here http://firmware.diydrones.com/Copter/2015-06/
    Up til now there has been updates on the "latest but the last update is 8 june.
    Is it placed elsewhere or?
    in github I can see there has been changes.
    Just of curiosity/ Goran
    • I don't think there are nightly builds per say, i think Randy or one of the devs actually triggers a compile after testing alot of new changes in dev, or else there would be alot of nightly crashes.
  • hi! What does the "EKF Variance" prompt on my HUD means?
