Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Thanks for the warning, Randy.
      I can't locate the link for the manual download of -rc5 for the downgrade.  Are you able to advise how to obtain it?
        We haven't stored the -rc5 binary anywhere (we have the source code though of course) and there's no easy way for me to revert the MP's beta version without yanking someone back from their day off so I'm afraid it's going to stay with -rc6 at least until tomorrow.  I just hope that people see the warning and are very careful or don't upgrade.
        • Many thanks for your explanation and for the very fast fix. I will go on with RC7 tomorrow. I did serveral flights with RC6 without any issue (4 flights with about 80 min flight time). I realize that every RC has a risk to use.
      • Same problem for me. For safety reasons it should be better to make only RC5 available through MP, or if you found the issue release RC7.
    • Thanks Randy
  • Hi!
    Yesterday I was testing ArduCopter3.3-rc6, after having upgraded from ArduCopter3.3-rc5 (with this firmware my Quadx remained stable, with good attitude and great consistency against the force that produces wind).
    First flight performed,
    I clearly saw that my quadx completely lost the tune, not stabilized, not attitude and very loose. I have tried to adjust it and do not get good results.
    Second flight,
    I changed the values of the following parameters:
    "INS_ACCEL_FILTER" = 42, changed to 20.
    "INS_GYRO_FILTER" = 42, changed to 20.
    With those values and flying in the AltHold mode, the quadx showed a very strange behavior, I lost control of the quadx, did not respond to the Throttle of the radio control and couldn't land it, so I had no more choice that impact it with a wall so stop.
    The damage was not severe.
    I returned to the Arducopter3.3-rc5 version, and everything is working well.
    2015-06-26 18-43-42 11.bin
    • Well, EFK2 error and LAND failsafe from very early ... similar to my error in the post above.
      Would you mind sharing the rc5 link please?
      • You need to downgrade to AC3.2.1, and then load the custom firmware ac3,3-rc5.
        I got several errors before loading the AC3,3-RC5, but I got it.
        ArduCopter-v2.px4
        https://storage.ning.com/topology/rest/1.0/file/get/3702706342?profile=original
        • thanks! do you happen to have the  tricopter version also?
