Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I think rc7 is a best firmware to the date. I will try to play with my hex tomorrow.
        Quad i played with today, and i could not make any control combination input to make it do anything wrong.
        Only issue i see is still with gps glitches when drone reaches the ground, it sometimes starts reajusting rtl position inches away from the soil, catches ground by its landing gear and flips. I think it is due to an error in baro readings or gps data - i noted sometimes altitude reading goes totall wrong saying, like, 3m altitude when i lower it down to just under 1m height, but it is hardware. Unless we get good reliable sonar there is probably little to nothing that can be done to make drone know it is inches away from the surface.
        Yet this issue happened only once. All other functions were great. Lift off is straight and smooth. No wandering about after lift off. I got it 100m into air, swapped to simple mode, flew all 6 modes, it landed back in rtl 30cm away from take off spot.
        Gps super simple mode still sometimes flips controls but as i stopped using it - simple mode seems to work just fine. Ma be super smle mode is not even worth keeping if it is impossible to prevent controls direction invert at close range.
        My 9yr old son flew it too, and is absolutely blown away. :)
        May be there is something bad in there. But compared to positive things i think it is a best firmware to the date. I crashed once in rtl as drone started readjusting position close to ground and got caught by landing gear but i think it is hardware, plus, it only happened once. I wish i had more time to help write this, but, so far it looks to be a truly great code. It is way better than old 3.2 and response to controls is really nice.
        I will try to link it with new banggood 3d storm32 gimbal, will see how that goes.
  • Why do I constantly get "error compass variance"? I'm testing on table, without arming, no 3d fix. Just connected and moving around. Also, on Mission Planner I see heading very slowly moving around while copter stand still. What is it?
    • Something magnetic nearby perhaps. I have magnetic tool holders on the wall by my workbench and if I place my quad to close, I get the same errors. Actually anything magnetic in proximity will cause that error.
    • Also, after calibration, offsets for the second compass was not saved. Is it ok?
      • I find sometimes MP does not report the offsets until you refresh the parameters.
  • how you all actually go back to 3.3-rc5?
    I tried to build ardupilot/arduCopter at revision "Copter-3.3-rc5". However there is no corresponding GIT tag in PX4Firmware, PX4NuttX and uavcan repositories. I tried revision tagged as "Copter-3.3" but get compile error.
    GIT submodule is added after Copter-3.3-rc5 so I can't use GIT submodule to locate the rc5 revision in  PX4Firmware, PX4NuttX and uavcan.
  • tried 3.3-rc7 on PX4FMU+PX4IO but it is not detecting the GPS. on the mission planner it says GPS: NO GPS. but on 3.2.1 the GPS is detected. any special thing i should do so it will detect the GPS?
  • I flown my quad with Rc6 last saturday, everything seemed to be ok, except for the landing, my quad almost tilted upon triggering land. :)
    by the way, which version of mission planner can you recommend, the official update or the beta update?
