Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Hmm yeah it is using a GentLED to trigger. Wonder if it somehow double triggered via IR, but it's all set to manual focus & no review, so it triggers pretty much instantly when it gets the signal and is good to go again quickly. I've taped the LED to the IR window and covered it over so there's no external light that can get in and mess with things. I never had any issues with image #/log mismatches on 3.2 with this same setup, so I'm wondering if it might be something else.
        • I haven't been able to geotag images for a while, on 3.2 or 3.3. I can't even find any cam_trigg messages in the log. I managed to tag in Mission Planner once recently using time difference but it came out a bit odd (registered all the photo's as a single line). Pix4D doesn't recognise the logs either. I use a relay type usb trigger on an s110.
          • That's really odd.  I've been mapping with 3.3 since it was released and after fixing the offsets in the geotag window.  But even when the Mission Planner geo tagging wasn't working, Pix would work.  I'm back to MP to geotag as it's more accurate (not really that big of a deal) though.
            • I'm sure it's something I have or am doing wrong,
              • Send a log file to Pix4d, they'll get you going again.  Nothing worse than not being able to work.  There's still a 90 degree kappa angle error when using Pix4d though.  No big deal, again just don't select high precision if you're using 2.0 Pix4d mapper.  Earlier versions don't matter.
      • What are you using to trigger the camera?  Gent led and other ir triggers are problematic at best lol.  I use direct multiport on a relay output, never miss.  If you can't match them up and you're using Pix4d, their geotag function will work.  If your geolocation is off, just don't select high precision.  Won't effect your precision, it just takes longer to process.
    • Based on the numbers you list, there are 16 fewer images than triggers.  This seems consistent with the behavior you have seen previously.
      GlennM, replied over on your other thread but in short, it's probably that the SD card can't keep up.  Try reducing the logging or replacing the card.
  • Hi Devs! Is it now possible to transfer telemetry data to an graupner HOTT system?
    • There is  a patch for HoTT protocol support by Adam Majerczyk
      I'm using HoTT for two years with APM and with PX.
      Also there are some MAVLink2HoTT translators. I made one of them. It's firmware for Arduino micro etc. You can easily find it within this group.
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
