Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Here it is
Anyone else have any issues with ROI? Or downloading dataflash logs? I just updated from rc12 to the official 3.3 release. Made several flights documenting local flooding due to "blood moon". One flight had issues... When I roi'ed the end of a pier, ending the ROI was unsuccessful. I could tell the ROI changed, but it did not turn to face the next waypoint, quad faced 180 and continued mission until I RTL'ed. I wanted to post a DF Log, however, the log that I thought was the correct one, just shows me sitting in the same spot, no flight data!!! Here is a video and wpt file. Will re-test after batteries finish.
https://www.dropbox.com/s/m649eqdxhs7rlqh/GOPR3236.MP4?dl=0
garden city flood 2.txt
I am on 3.3rc10 and I think I have the same issue with dataflash log - it seems mission planner either downloaded just a portion of a log or ready just portion of the log.
I am at work, I will try to upload the log when I get home.
here's the log
https://onedrive.live.com/redir?resid=38BA3875BBC10887!3656&authkey=!AKqbVVnXuOsjmgg&ithint=file%2cbin
If I have a copter with LidarLite on it and fly a Auto mission and set the height to 25 m in mission planner will it use the Lidar to keep the height on 25 m above the ground?
I use to fly in areas where there is no terrain data so it would be nice if I could use the Lidar to keep the altitude over ground.
Alf,
No, I'm afraid the lidar-lite altitude is not used during missions. We're looking to add Terrain Following during missions using the google maps altitudes to Copter-3.4 and we've discussed also incorporating the range finder altitude into that but I can't make any promises yet.
It's slightly more complicated than it seems because for a proper solution we need to allow the pilot to specify what altitude they want to be used during the mission (i.e. alt-above-home, alt-above-sealevel, alt-above-terrain) which affects a number of parts of the system including the GCS, the mission command storage and finally the vehicle position controllers.
Hi Randy!
For thoose who fly in an area without google maps altitude (for me Storlien, Sweden) and not so flat landscape it would be a great help to be able to set desired altitude to be used by Lidar, and then just plan the route.
Is it possible to implement it as a security parameter in auto to not go below ground altitude xx m. reported by lidar?
Holding my thumbs for that it will be implemented in future releases for this great product.
Not to mention it is just plain cool!
Randy, do you already have a Lidar lite or does somebody need to send you one?
Is 3.3 out?
Checked in MP for beta FW and I got "APM:Copter V3.3 Quad"?
Or a bug in MP.
I think it´s out since 14 hours.
