Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
just flew in a bit of wind.. on 3.2.1 i had no issues stock params pids ..on a zmr 250 frame... i just used 42hz instead of the default.. drifts slightly to the left.. maybe because of the wind.. but omg my heart was racing.. used a 20 c 1300mah zippy batt 10 bucks on hobby-king got about 4 min before it gave me my warning..
3.3 is just too buggy now..... im using the micro pixhawk from hobby-king https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct...
with the apm micro sensors.... no issues once i switched back with the compass issue..... even after i choose which one.. from what i understand the pix picks the external one if its attached automatically but i had to manually go into mp and choose 1 which is external.. then i 3.3 rc12 all the issues arose on a clear day too.. everything calibrated... now my external gps takes a long time to lock on..
when i use my 450 quad with apm 2.6 its almost instantaneous ..
maybe because its a official one and hobby king uses Chinese clones i dont know.. but once i switched back flew great.. alot of up and down and a little drift to the left.. but with 10 mph winds maybe thats normal.. held loiter fine..
with all my money invested around 500 dollars on this little 250 quad i was sooo nervous lol..
the cool thing i didnt have to touch the pids then again i was only hovering and in a small back yard... but pretty stable
heres some pics of my setup..
1806 motors.. Chinese qav250 frame.
12 amp afro esc's
micro pixhawk with gps and pd board
3 blade 5x3 props
spectrum 6210 receiver with satellite
dx8 radio
3dprinted parts for cell phone holder
telemetry kit
galaxy s4 phone as tablet
ppm encoder
Reload the params and double check the internal is still set to be off. If it is then that warning seems to be a mistake doesn't it?
yup im getting a green lite on the pix now..
im getting bad velocity but before i was a yellow.. so now im sure it will fly... 3.3 has bugs that need to be fixed and looked at
auto analysis doesnt work anymore? is something wrong on my end? I get pop ups saying 'time' and then 'bad input file' but the logs open fine when i review them. Also im using the latest beta mission planner
Parachute function test was success with firmware 3.3. Test sessions covered two manual ejects and two automatic recoveries. One motor were killed mid air by cutting power off using relay. In this blog you'll find more info.
how much weight those it all add up?
very cool!!!!
I flew 3.3 c12 tonight and flew in alt hold and pos hold and both were improved from 3.2 I think. Alt hold was more consistent even in yaw'ing and or tight circles. Previously my quad would gain in one direction or lose in another before but now it's just... well ... awesome. I then flew around in pos hold up to and round 15 mps and noticed a more consistent posisition hold and braking to stop position. Not a huge gain over 3.2 but seemed more consistent. Smoother would be the best way to describe it.
The biggest improvement for me was seen when I chopped the throttle from about 45 meters and it dropped like a rock BUT was completely stable without the wobble from the prop wash that was VERY apparent with 3.2. NICE!!! WOW!!!
Just a side note I didn't do any auto tune after updating to 3.3. So it was very apparent to me even without that it was much improved.
I didn't do any auto.... But the two main things I want't to see improve did!! Altitude. [ over water this is critical ] and pos hold.
But perhaps the best thing to mention or note for me is NO errors mentioned. No EKF or Compasses inconsistent or anything. It just fire out of the box sweet.
RK
Hi Richard,
What are the specs of the craft you were flying? Thanks -
Fred
Give or take it's a 550 quad I built myself with 1100KV T motors and a 3s 5200 batt. I use and all in one ESC. A Taranis set up .
