Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Hi. I have asked for the same thing too. It is useful for those of us who use a double power system to take off as soon as the battery is replaced.
      I think it will be done for 3.4
    • AH!! that's the reason because batt Beep under time, thank's
  • sure - i totally get it. if i had a specific mode already dialed in i would be hesitant to fuss around with a new mode. but I believe you can do everything needed on adjustments with poshold as well.
    Copter-3.3 is out as the default version!  Thanks again to all the beta testers on this thread!
    • Installed and flew it today, all seems to be well except of gps switching between units. I ended up disabling that parameter for auto switch and then it was all fine, very stable.
      Other thing - for my armattan i set all filters to 40hz from default 20hz and it works way better this way.
      Looks like a great release.
      I think for dual gps systems a better logic would be to put in a check if primary gps unit goes completely kaput - like time update stream stops or something like that and only in this case to switch into a backup unit. This 'on the fly' switch mode should probably be removed as in practical reality it causes more trouble than good.
      • Hi what gps are you using I had this problem when I had a 3dr 6h and a Neo7 which would cause it to move say up to 2ms when it switched gps I cured this by changing to two 3dr gps so now it's hardly noticeable the moment between the two gps hope this helps
        Stuart
    • Congratulations. Thanks all devs for your efforts.
      I am already on 3.3rc12- Do I need to update to GA code? or is it still the same code and I don't need to update.
      Thanks.
    • Hello Randy,
      is the version 3.3 still without mkblctrl? If so will the mkblctrl be discontinued?
      As I am using these ESCs I cannot upgrade.
      Regards
      Derek
    • Woohoo!  Congrats on hard work well done.   Will there be a new release of MP so some of the new features in 3.3 show a parameter value & description?
    • Congratulations!
      So when does the 3.4 beta testing start?
      Thank you again.
      We appreciate what you do.
