Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • +1 For that!
        It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
        • If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
          • This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
            • yes please, oneshot support and blheli 1wire update through copter software
              So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
              RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
              Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
              I for see a lot of questions
  • Hi,
     Do the latest firmwares support V and T setup for hexacopters at all?
    3702119253?profile=original
    • I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors).  It worked out OK.
      Duffy,
      I'm afraid we only support X and + for the Hexacopters.  It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
  • Hello,
    While following the wiki to configure PX4FLOW and Lidar-Lite v2 on AC3.3.1, I am wondering when does the autopilot actually use the PX4FLOW camera. Would anyone mind to let me know if I am right or wrong in the following.
    - Autopilot reads PX4FLOW only in OF_Loiter flight-mode?
    - Autopilot reads PX4FLOW in all GPS-assisted flight-mode, but does not read it at all in non-GPS flight-mode?
    - Wiki requests EKF_GPS_TYPE = 3 during PX4FLOW test flight. After that I should set it back to EKF_GPS_TYPE = 0 in normal flying?
    - Whenever the flight mode requests X/Y position estimation the autopilot reads both GPS and PX4FLOW. EKF then blends them together for autopilot to use?
    - OF_Loiter is a flight-mode that needs X/Y position estimation but does not read GPS. It only reads PX4FLOW?
    Thanks for clarifying my confusion,
    Wilson
    • I'm also completely confused on whether I can use optical flow sensor without lidar or not.
      Wiki says it does not use sonar readings anymore and I see flat line for EKF5.meaRng.
      Lidar is additional $200...
