Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hello every one,
    after autotune with aggressive 0,05 i had the following values. only stab p for roll and pitch was too low. i raised it. the copter flies well, in windy days too. but there´s a big problem with my ccd cam. it wobbles strongly and it´s no rolling shutter. my question is, if it is a mechanical problem with cam or a pid problem.
    and the problem is taken the most affect only at flying against the wind. my vibrations aren´t bad.if i compare pitch or roll with yaw i see at pitch and roll many peaks.yaw is very clean and i love it. could the peaks be the reason of my problem?
    the frame is a h4680 with 4s, tiger mt2216 900kv and graupner eprops 11x5.
    attached are a picture of pids, a picture of pitch and a log.
    i hope, someone can help me.
    3702124578?profile=original
    3702124289?profile=original
     3702124447?profile=original
    2015-11-12 16-20-24.bin
      Hi Speedy,
      Your vibrations are pretty high. Large props into the wind can vibrate a fair amount especially if the frame is flexible. Your tune doesn't look like it is causing the problem though.
    • The cam is a sony 600tvl.it should be ccd. It's no rolling shutter...more big waves.
      I think arducopter has still mega problems with alien type frames. I make a new pitch tune and test or i will reduce p. I don't understand the peaks. Normall it should so clean like yaw.perhaps randy or leonhard thall has an idea. And stab p should be higher.
    • Hulk: Try to repeat pitch autotune or try to reduce it manually, thats in part your wobbles ccd and other problem is that if your camera wobbles probably isn't ccd, it's cmos, are you shure?
      Yes, a wonderfull weekend here ;) .....but I'm not have with me my copter :(
    • No one an advise ? Or because it´s weekend?
      • If it's an Alien 680 frame, I have one too and am having problems getting it tuned. From what I've heard many do.  Everything is tight and COG good. AT was done with AGGR at .07.  The copter is not stable after 2 AT's.
        My PID's are quite different than yours. I'm starting to think I need to put some good CF props on this bird. With the cheap Gemfan CF VIBE's were lower, but over 500g thrust I don't use them. Currently it has APC MR 13x5.5 and it just doesn't seem to be as responsive plus does wobble.
        I've never had a quad with these goofy PID's.
        • This is also a Alien 680 tuned at an aggr of .05.  The tune is is rock solid.  This is an X8 though with Sunny Sky 4108s 14 480kv motors and 15" propellers running 10ah4s packs.
          3702801679?profile=original3702631891?profile=original
