Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Thanks for your answers.
      I checked the motors and ESCs and they were still working fine. But I will do high load tests again today.
      The copter flew perfect before the crash at this day and the day before, so I don't think sync issues could be the cause.
      I am an experienced solderer and I made sure the solder joints were all perfect!
      • Would it be possible to post a log with the copoter flying OK? I´m very confused about the log you posted because I can´t find the spinning in the mag or imu readings. In the log it looks like a controlled descent.
        There is definitely something wrong with the sensors - in the map logging there i a sudden jump in position along with an EKF error.
        • Here is a log of the Copter flying perfectly fine!
          Had to rar it because otherwise it would be over 7mb.
          didn't have a smaller log with active GPS.
          Thanks for your efforts!
          2015-11-21 11-36-01.rar
          https://storage.ning.com/topology/rest/1.0/file/get/3702802201?profile=original
      • See this is the thing about "faults" is the never really go "hey, I'm about to break" Just because they worked "yesterday" doesn't mean they will work today :( And the thing about these darn desync issues is that they don't always pop up and rarely when you expect them. Intermittent problems are the hardest to diagnose. The logs "should" give you an idea where to look but I am so out of touch with all the new logging info that I would not have the 1st clue where to look. You might not even have the needed logging enabled. There are quite a few videos on desync issues and how to reproduce them so you might want to take a search on youtube.
        Are you sure all of your props were tight? The only time I have seen that kind of spin on one of my hexes was when it spun a prop lose and down it came spinning like a top. The only time I have had a desync issue was on my 250 quads and they tend to just flip and crash.
        But I would definitely look at your vib levels even so as they are not good and are bound to cause you issues in the future. The video showed some pretty heavy oscillations [vibes] and whilst I do not think they are what brought down your bird "this time" I would fix them before flying again.
        • hey, you are of course right but it's really strange, that it flys fine and from one second to the other it just fails.
          I am also very new to the logging thing and just did basic checks before. Therefore I also don't know what to look for.
          The props were all tight!
          What vibe levels are ok? Do you mean the VibeX, VibeY, VibeZ parameters?
          The high z vibes are from the landing, I guess.
          https://storage.ning.com/topology/rest/1.0/file/get/3702802306?profile=original
    • The jello in the video confirms that is is pretty much either a vib issue or a desync issue or possibly both. Normally a spin like that means one or more of the motors went wonky. This could be an intermittent ESC issue, cold solder issue, a wiring issue, or a motor issue.
      • In a desync / esc issue shouldn't the rcout channels log the failure by its attempt to raise the throttle in order to try to maintain the attitude?
    • Hello Dave, Have you checked your motors
      • Hello Dave,
        I thought it could be a motor sync issue, but after taking a look at your logfile it seems that they are fine.
        There is something going on with ekf. Don't know what is it. Someone more experienced with ekf would probably figure it out. I see that the ekf mag innovations are high and your vibe(x,y,z ) are very high despite the IMU vibration levels are fine.
  • Still unable to find the THR_MAX setting in 3.3.1 with Hexacopter in X. Does anyone else see it? Is it a missing setting in this version? My copter won't take off.
DIY Robocars via Twitter
Sunday
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
