Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
You can not use 3 compasses. The 2 external compasses have the same i2c address [this can not be changed until the makers of the units pull their heads out and allow us to set the i2c address ourselves] and since they both have the same i2c address the flight controller can't control them. Where did you see that it was a good idea to try to use 3 compasses?
I WISH I could get my gear to go up or down using the hawk. I have to attach mine to my RX directly and just use a switch on my Taranis. Works fine but still annoying.
if you are using Tarot medium and large landing gear you can very well fry your landing gear controller, lookup on rcg I've posted couple of pics where power protection circuit is untouched, while the microcontroller chip is fried.
That's good to know. The only thing holding me back has been the extra weight, but hear many stories of the LG failing.
It depends on your landing gear controller, but hopefully nothing happens.
Hello .. got a bit of problem after changing one of my ESC that burnd out .. i alsow updated to APM:copter v3.32-rc2 and having some problems that im not shore how to fix. the copter feels werry unstabel and hard to keep altitude . i have tested to change both trottel midhold.. and manual tune it.. always making it wors so i hade to go back to standard . auto tune is a no go sins i cant get althold to work agen.. i some times get BAD ACCEL HEALTH. after i upgraded to this verson .. it might have somthing to do with im using a clone im not shore..
.. maybe some one could have a look on my log.
frame is H4 quad 670mm
3108 700kv sunnysky with 12 inch carbon props
multistar 4s 8800mAh batt.
Pixhawk clone ..
2015-12-11 15-51-53 5.bin
Did you calibrated your ESC's after adding a new one?
It could be that the new ESC is out of sync with the others.
That would be the first thing I would do after changing one of the ESC's.
thanx Igor .. yes i did calibrate the ESCs..
I have bin looking around here on the forum now for any thing simulare.. starting to belive its the cold wether.
but i dont know sins i have not hade it up flying good before the cold wether started here,
maybe some one could confirm that if i disable the 2 IMU it would be better ? no when this cold wheter fenomen for pixhawn happens dose the craft become unstabile?
My Bluetooth connection also doesn't work any more after updating Mission Planner 1.3.32 to 1.3.33.
Worked again after downgrade to Mission Planner 1.3.32.
I'm using F2M03GXA bluetooth module.
I somebody could confirm I would open a ticket in Guthub.
Seems that when mission planner try to open serial port, it runs some fix port routine and also tries to write data to the socket. I assume that it does make sense for some scenarios but for bluetooth it just kill the po port. Commenting this lines do open the Bluetooth with no issues.
It's worth checking the other serial settings on that port - I had my serial settings reset by a recent firmware upgrade (I think).
51
52
53
54
55
of 449 Next
