Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It is strange, that buzzer generates signals after ARMing.
My Mariner copter is closed body design, and never hear the buzzer.
I do not think that anybody will listen it in the flight! For security reason is better to disable the signals after takeoff.
Right of course! Sorry, we've seen this before, it just slipped my mind. Thanks for that Greg!
@Randy
Is there a way we could check pixhawks not yet integrated in a system for this fault?
It would help a lot
Duffy,
The divergence should be visible through the mission planner's Status tab (go to Flight Data screen and look on the bottom left) and then compare az vs az2. The difficulty is that the problem is intermittent. So for much of the flight above the numbers are very close. In fact, we have a pre-arm check that will warn, "inconsistent accels" if there's a problem before takeoff.
Randy,
Every day in every extent I am learning something more.
Thank you for the graph and the explanation of the problem source.
I must confess I noticed it but didn't know how to interpret the sudden separation.
This one goes into my knowledge book.
I am no log expert, but here are my 2C
Your vibration levels seem reasonable for me, so I don't think it's a vibration issue.
But when I checked you CTUN.ThrOut it has a mean value arround 510, and your THR_MID is set to 700.
So when you switch to one of the altitude mode your throttle jumps to 700 and your IRIS+ fly's to the skies.
Try setting your THR_MID to 510 and see if that helps.
I have exactly the same problem with new firmware 3.3.2, after switch from stabilize to alt hold, flying up at full throttle. Here is the link to my publication.
I have tested on two different Pixhawk installations, both had very good alt hold and auto before the upgrade...
I am needing some advice. I had to do a hard restart of my laptop and when downloading Mission Planner,i ran into a problem that needs some clarification. When downloading,the driver download failed on laser navigation,but would still let me finish download. I am not using laser at the present,SO,will this affect MP, or my normal firmware,or the way the copter will fly?? A little advice would be appreciated. Also, if there is a way for me to get those drivers to pass would be great as well. Windows 8.1 with signature cert disabled. Thank you in advance. Frank.
Sorry, but for some reason after disabling driver sign cert again,they loaded fine. Thank you anyway. Frank.
Randy
Do you know if the FrSky Taranis Telemetry will be supported in 3.4 so there will be no need for a teesny board just a direct connection to the smart port on the X8R rx? I know there were people working on that. I think that would be a huge upgrade to the copter FW as it has become a very popular radio and adds a tremendous amount of info to the pilot without the use of a separate GCS. I would even go so far as to say it adds a great deal of safety being as one can see the battery level and or get a warning when it gets low.. let alone all the other data it provides.
