Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
you're welcome.
my only regrets is that I've no skills in coding :-(
and a poor English ;-)
I've updated the Warning #1 to tell people to hold off on trying AutoTune until -rc2 comes out which will include some fixes from Leonard.
Wasn't auto tune supposed to be repositioning during the tune phases, incase you experience drift off due to wind influences.
I thought I did see this in the asome video of Marco where he did test the auto Tune?
Just flew into a tree during auto tune, as the last phase (the yaw tuning) is changing the orientation, and getting it back when the Front of the hex isn't where you expected it to be, makes it a little harder to stear away... (Pure operator error, as the autotune did go fine)
Unfortunately by hitting the tree it dropped into a pool of water, so using an airblower now to dry it out, taking every component apart..., I could get it out of the water in just seconds, so hopefully no expensive parts lost (did lose a motor / esc, which was smoking when I got it out)
Log is available incase Leonard needs it.
Hi Erik,
Oh, that sucks!!
No, it doesn't hold position yet. I have it planned for the future but I will get the basic functionality in there first. I will also look at alt hold tuning as well.
The copter should hold it's heading during tuning.... The log would be helpful, thanks!!
Yeah, but you need to experience everything ;-(
Tune looked fine, except I did see very minor altitude jumps, of 30, 50 cm every now and then during the roll and pitch tuning..
I also did see that it is not alternating like it did before (with v3.21)
So in practise this means that you can have a right move due to the roll, followed by another right move, and so on.
Before you did right, left, right left, and that kept the copter more at one spot in the air (obvously depending on wind drift)
Same on Pitch, where it keept moving away by dipping the front more for several instances.
You get the picture, it should be visible in the log as well.
Good luck, you guys do asome work on the software if I see the number of fixes you all handle on Github (get a mail on every change, just to see what is improved... ;-)
Ok log in the next one, as it was just over the 7 Mb sizing limit
Including log now...
7.zip
Sorry the adjustment to hold the yaw heading will be in the next release. Sorry!!
No prob, I simply should have canceled the tune, and hit RTL switch which I had configured, but I was already to close to the treeline, and RTL will take it up to 20 meters, which wasn't possible at that moment. The stupid thing is that I a full FPV on that drone so just a quick look at the screen (on the transmitter) should have told me the heading....(and switching to loiter, would have kept in in one spot)
But line of sight is still what I fly in these testing cases.....
FWIW: you might consider spraying everything with Corrosion X.
Thanks Steve,
I have used an airblower, after takeing everything apart, and it looks like I was quick enough to get it out of the water, so even the Pixhawk looks fine.
Luckily it was not Salt water, so I have high hopes everything is fine...
