Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi Vic33,
      After autotune you should land and disarm then take off and fly again to test the pids. You can also test them by moving the autotune switch back to the off position and back to the on position. Be careful though as a bad tune may need you to quickly switch back to the the off position.
      • Thanks leonard,
        But i know that, as i don't make a autotune every days, just before i had a look on the process to refresh my memory, and i'd choose the second method, that why i surprise, at the end of the process i'd turn off auto T , then switch on.
        it's could be me that dreamed, or due to my 3 position switch (taranis) for autotune that i'm not full turn off by just put it meddle position? even if auto tune on/off is confirm by MP in my workshop...
        Don't be affraid, i'm used to pilot, i've 9 years of flight experience on this type model (multirot), and i have the chance to have a great area test zone with about 2m height of reeds for the "dangerous" test, moreover as it's dev quad, if it crash i'll don't cry ;-)
          Hi Vic33,
          No problem, thanks for your feedback and help!!
          • you're welcome.
            my only regrets is that I've no skills in coding :-(
            and a poor English ;-)
    I've updated the Warning #1 to tell people to hold off on trying AutoTune until -rc2 comes out which will include some fixes from Leonard.
    • Hi Randy,
      Wasn't auto tune supposed to be repositioning during the tune phases, incase you experience drift off due to wind influences.
      I thought I did see this in the asome video of Marco where he did test the auto Tune?
      Just flew into a tree during auto tune, as the last phase (the yaw tuning) is changing the orientation, and getting it back when the Front of the hex isn't where you expected it to be, makes it a little harder to stear away... (Pure operator error, as the autotune did go fine)
      Unfortunately by hitting the tree it dropped into a pool of water, so using an airblower now to dry it out, taking every component apart..., I could get it out of the water in just seconds, so hopefully no expensive parts lost (did lose a motor / esc, which was smoking when I got it out)
      Log is available incase Leonard needs it.
        Hi Erik,
        Oh, that sucks!!
        No, it doesn't hold position yet. I have it planned for the future but I will get the basic functionality in there first. I will also look at alt hold tuning as well.
        The copter should hold it's heading during tuning.... The log would be helpful, thanks!!
        • Yeah, but you need to experience everything ;-(
          Tune looked fine, except I did see very minor altitude jumps, of 30, 50 cm every now and then during the roll and pitch tuning..
          I also did see that it is not alternating like it did before (with v3.21)
          So in practise this means that you can have a right move due to the roll, followed by another right move, and so on.
          Before you did right, left, right left, and that kept the copter more at one spot in the air (obvously depending on wind drift)
          Same on Pitch, where it keept moving away by dipping the front more for several instances.
          You get the picture, it should be visible in the log as well.
          Good luck, you guys do asome work on the software if I see the number of fixes you all handle on Github (get a mail on every change, just to see what is improved... ;-)
          Ok log in the next one, as it was just over the 7 Mb sizing limit
          • Including log now...
            7.zip
            https://storage.ning.com/topology/rest/1.0/file/get/3702838239?profile=original
          Sorry the adjustment to hold the yaw heading will be in the next release. Sorry!!
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
