Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
14kg quad?what motors is that?
Using u10's on 12s. but I am upgrading to u11's now. U10's were a little bit underpowered.
Hi Craig, sorry for your crash.
Your idea for a servo rail voltage failsafe is a nice one. However it would not have saved you. The fact you would power also via the power port would not have saved you either. Why? Because if you get a voltage above 5,7V (short burst spikes for example which are frequent if you connect servos on the servo rail), Pixhawk will protect itself by shutting down.
So the only good way to avoid your crash was to follow what is written in the manual and plug a zener diode (trimming any spikes above 5,6v) on the servo rail.
Hope this helps,
Cheers
Perhaps a bidirectional TVS would be even better as they can sustain larger current.
So if a switching and noisy power system decide to behave badly, a bidirectional TVS will shut it down very quickly.
There are number of companies producing them but just for example littlefuse:littltfuse bidirectional TVS
Just my 0.00002 cent.... (has been limited by a TVS) :-)
Cheers
Henri
thx for the link, this looks interesting.
As far as I understand when servo rail power goes above 5.7, power from that rail to the pixhawk processor/electronics is cut by a switch or ideal diode or whatever.
But pixhawk will continue to be powered from power module port (as long as it is below 5.7v)
Is it right?
Craig was not using a power module. So Pixhawk will shutdown if it sees a voltage spike on its servo rail. That is why you need to install an external zener diode on the servo rail that cuts (trim) any voltage spikes above 5.7V.
Correct, but I could have had a 5v bec plugged into the + and - pins on the pwr module, and that would have saved my bacon. Pixhawk would only have shut down power to the rail, not shut off completely. At least that is how I understand it now. Am i right or wrong?
The order of priority taken by Pixhawk is : 1-Power port then 2-Servo rail. The servo rail power comes into account if the power port is not used. (there is also theoritically another powering option via the USB port which is not used in flight, only on the bench).
I have to check the theory on the bench that in case the power port is used, if you get a high voltage spike on the servo rail (even if power port was powered), the pixhawk will not reboot as this would happen if powered only by the servo rail....
425
426
427
428
429
of 449 Next
