Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Randy- I agree, OF has been working very well. Check out my blog post about my experiences with it.There are still some bugs to get through, but it has been pretty exceptional so far!
    • I bought a PX4 optical low/sonar module more than a year ago and could not get it operational then. If it is at all strait forward I would love to make another go at it! just need to sort out some vibration issues first.
      The video show the quad holding position and altitude very well, great job!
  • Today I testet my LIDAR, connected via PWM. It works great in AltHold and PosHold.
    But in Auto mission the LIDAR is not working. I hat a Mission with descending to 2 Meter. The 2 Meters are barometric, If I put some thing under the copter there is no reaction from the Copter. I guess this is a bug.
    Also the RNGFND_OFFSET makes no changes even if i put in extreme values.
      Andre,
      Yes, I'm afraid that the Lidar is only curently used in manual modes (AltHold, Loiter, PosHold).  It's not used in AUTO.  That was the case with AC3.2.1 as well by the way.  Hopefully in AC3.4 we can get that working, it's not trivial though because we will want the user to be able to specify for each waypoint whether it's an altitude-above-home, altitude-above-terrain or an absolute altitude.
      • This would be a huge improvement for our company.  We've got a 1300 X8 for carrying lidar, but the lidar is limited to scanning no higher than 80m.  For our mountainous terrain and huge tree canopy, there's always a possibility of a tree collision.  The possibility of using the lidarlite (or scanning version) could save our large lidar from being damaged.  I was talking to the owner of Phoenix Lidar about integrating his AL3 into the autopilot.  The Velodyne 32 head scans 10 degrees forward and 30 back.  No reason is couldn't help with terrain info while it's scanning for topography.
        • Shaun: (sorry to the group for an off topic question) why lidar for topography when you can get high resolution 3D from photo images with SFM through software like Agisoft PhotoScan? perhaps a reply by email fredojean-at-gmail.com. Thanks a lot. Fred
          • SFM is a great, inexpensive tool for bare earth.  Unfortunately rarely do we have bare earth.  Volumetrics at excavation sites and open pit mines are really your only customers.  Lidar penetrates vegetation with multiple returns (not all lidar though, some single return).  Density is also much more consistent, don't believe all the SFM coolaid lol.  Bad light = low to no density.  Now to make this on topic, any way to incorporate our 700000 points per second lidar data into arducopter 3.4 code for collision avoidance : )
            • Thanks a lot for your quick (!) response. Limited knowledge of lidar; I didn't realize it has that penetration...  700k/s: that would be quite a bit more data to process. : ) = ironic or happily wishful?
      • Oh, I understand. Of-course it is a very good idea to have different altitudes selectable for the mission, that makes it safe and easy to understand. So I will hope for 3.4
        But as Roberto asked, I guess in Guided-Mode it is easy to get it working as per default?
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
