Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Spline 3D?
    Did an Auto-Mission with a few spline waypoints (all at alt 100m) and realize that spline also seems to  work on alt - does this really make sense?
    Hubertus
    2015-06-10 18-23-33.bin
      Hi Hubertus,
      We thought it made sense to make spline work in all three axis. This makes for beautiful path planning shots. It is a little harder to visualize and the mission planning tools probably haven't made full use of the 3d nature of the path in the way they display the information.
  • Hello, i have installed RC5 from May 23 and have find a BUG?!?
    I Have a Graupner MC 16 Hott with GR 12 Receiver over sum to Pixhawk.
    So over Sum i can not order the Channels and must set RC1-3_map to order Roll 3 Pitch 2 Throttle.
    After Flash i make for First time with Mission Planner 1.3.28 under Advanced Settings > RCXYZ_map write this Para and disconnect Pix from Power.
    Than reconnect reload the Power and make Wizard without Problems.
    After arm and throttle up the copter full roll to right.
    3702024864?profile=original
    @ SD Card Log in main directory:
    RC Map Unmapped?
    Greetings from Germany
          Dennis
    2015-06-10 17-41-58.tlog
    • Just in case you didn't pick up this is a known problem and won't work until rc6.
    • No problem, thx
    • Dennis,
      why do you want to assign the sticks of the Mc 16 to different channels? You can change them in the Graupner setup. Just choose "Set -> Grundeinstellungen -> Steueranordnung 2, Motor an K1 - kein, K8 verzögert -> ja, Leitwerk -> normal, Querr./Wölb -> 1QR" and it should work without changing the mapping in the pixhawk.
      LG
      Hubertus
      • this is the standrad Setting in MC-16 Mode 2
        so i must re map RC Channels from 2,1,3 to 3,2,1
        MC-16 Hott with GR 12 @ Sumo8 cannot reassign RC Channels
        My Problem is at the Moment when i Flash ArduPlane > delete SD and MissionPlanner local files and Flash then 3.2.1 i have the same Problem.
        For Flashing rc5 i have not this Problem.
        I have reset by Long Press Button on Pixhawk and reflash 3.2.1 and so.
        Copter will every roll to the right.
        When i not remap the Channels after reflash 3.2.1 i have not the Problem
        • OK, I was wrong. I have MX-16 Hott and GR 16 and this setup works without changing the rc mapping.
  • I have teensy, 3dr radio and minimOSD that I would like to interface with the pixhawk. Can I use the extra serial port so that I will not use a y-connector on telem port2?
    • I also like to know that if we could use port-2 for minimOSD.
      And is it possible to connect a second GPS to the third port?
