Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
My props are well balanced and everything seems secure, but I will give it a good once over to see if I can find anything that would be contributing to vibes. I guess there is no reason delving into this further until I can get the vibes in line.
please elaborate on the alt jumps on x2.... are you using foam/case or not.....
I though it only was my old x2....
I have x2 on 2 systems with rc7 and other than certain altitude drop during fast flying it has no jumps or unexpected movements.
If I let it be on its own it recovers altitude to what it supposed to be. Drop of altitude is usually apparent when it is lower than 3m or so, may go down 2m or so, then crawl back up. there is foam on the baro, on both cases.
I also believe all parameters should be left exactly as autotune sets them, for best performance. there is one parameter people were writing about here - ATC_ACCEL_Y_MAX - boosting it up from autotune value resulted in extremely sensitive vertical movement in stabilize mode and it made practically impossible to set drone to sit on a constant altitude in stabilize, in my case I moved it from 17000 value to 27000 value.
But it did not affect behavior in the alt hold at all.
Hi Paul,
Especially with rc7 I think people should generally only drop the ATC_ACCEL_X_MAX values unless they want to have very aggressive handling.
The parameters
MOT_THST_BAT_MAX
MOT_THST_BAT_MIN
MOT_THST_EXPO (0.65 to 0.75)
MOT_THST_MAX
should be set by the user before autotune.
@leonardthall: Wanted to follow your advice and lower ATC_ACCEL_X_MAX.
did a find on the full parameter list but ATC_ACCEL_X_MAX isn't present. See screen grab.
Thank you in advance.
Regards.
Henri
Sorry Henri,
the X was a replacement for R, P or Y. So each of the parameters you show in your screen shot.
@leonardthall: Good morning and thank you very much for answering.
This information is worth gold!
Assuming that the numbers are for very aggressive handling, what would be the numbers for a very tame (meaning camera and video work) for a 1 meter multirotor?
Regards
Henri
Here are a few screen shots of things I noticed in the log I recorded today.
First, comparing ThrIn and ThrOut, ThrIn and ThrOut seem to be right in line while flying in stabilize but (adjusted by my hover percentage) there is a clear and somewhat disturbing introduction of noise on ThrOut when I go to PosHold.
Second, The barometer output "BarAlt" seems to have a ton of noise. I don't know if this is typical behavior for a barometer.
I will be the first to admit that I am unlearned, as far from an expert as I can be, and sometimes quite obtuse, but I can clearly see that there is a problem when I fly. Whether this is a software filtering issue, or a hardware issue of some kind, I cannot say. Hopefully someone can enlighten me and lead me to some sort of a solution.
Jeremy, could you post your log? bad vibes usually affect alt-hold flight modes, because it is not only the baro which is used, but all the accs and gyros.
I suppose I shouldn't assume that it is not firmware related, but should rather post my finding and let the experts tell me if I have a software problem or a hardware problem.
I have an AUAV-X2 mounted on top of my asymmetrical quad. It does not receive any direct prop wash, it is mounted in a case and does have foam sandwiched on top of the barometer. What I am finding is that the quad flies fantastic in stabilize but it is vertically twitchy in anything that uses the barometer. When hovering, you can hear it bouncing up and down with no inputs. If I pitch forward in alt hold or pos hold, it will audibly pulse the throttle instead of maintaining a consistent output. I feel like I am constantly chasing the stick to keep the altitude somewhat consistent. This issue has almost rendered any auto modes unusable as I am always too on edge to really enjoy flying. The upside to this is that I have become quite proficient at flying in stabilize, which was something I lacked before.
306
307
308
309
310
of 449 Next
