Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I did a couple of long flights with rc7 this evening. Everything seemed fine. No different to rc5 that I could tell. Was a little windy and it held position well.
      • Running my DIY quad based on F450 frame with rc7 firmware and it is much better behaved than it was with rc6. I had had a couple of scary takeoffs with rc6.
        I tried to do autotune today but it was too windy and I spent most of the time re-positioning so even after 15 minutes it wasn't done even though I'd selected autotune roll & pitch only. Will try again in the morning (if it's calm) and report.
        • OK, this morning was calm so I did roll & pitch autotune with rc7. Roll took almost 8 mins while pitch was somewhat faster. The quad was very stable and well behaved except at landing when it refused to slow the motors & disarm until it had flipped over and mowed the lawn.
          Tried a second flight with the new settings and again, great handling but disaster again at landing. This time the props were digging through the dirt before finally shutting down. Is anybody else having landing problems?
          Hear are a couple of screen shots from the first flight. Unfortunately Default + IMU does not give me RCIN & RCOUT logging: Both THRIN & THROUT were at "0" during the excitement.
          • These look normal to me. If it was fine in flight I doubt the gyro is the issue.
          • landing in RTL seems to suffer from position adjustment errors IMHO when drone gets really close to the ground, then it catches at the ground with landing gear and flips over. sometimes it happens, sometimes does not.
            it actually happened today once to me, after not happening for quite a long time. it helps to have a mapped emergency engines stop function to one of a switches on the TX so you could kill motors at once if you see this dance started happening. .
            • Hi Paul:
              I was in AltHold both times but admit that I might have had some horizontal motion when it touched down. What bothers me is that even with transmitter throttle at minimum the motors are revving when flipped over (I do have Copter min throttle at default 130).
              Re: "Emergency Stop Motors", I wasn't aware that was now available in 3.3. How quick does it act?
              • update MP to newest beta version. it is function code 31. I assigned it to lower right switch on taranis, a flip switch. it is immediate. it is extremely helpful. if you hold it up for 2 sec it disarms the drone.
                • I don't have access to a windows pc but I did find it in APM Planner v2.0.18rc2.
                  I'll configure my Taranis the same way. I guess I'll have to be very careful not to flip the switch while it's in the air;-)
                  This will be extremely helpful. Thanks for your help.
          • Here's the missing second screenshot:
