Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Randy, do you know, is it normal?
elevate your compass as much as possible, than run compasmot.
Compassmot almost at zero. Also, do not see any problems on flying. On one copter I had a very huge compassmot results, and I even can't fly without errors (and landing as failsafe). Here, I do not see any troubles while flying.
Is the issue with AUAV-X2 fixed?
Darn. It's suppose to be fixed. So what we may have here is a failure of the fix and the dev testing of the fix.
I don't have a board myself but we will review the patch and see if we can spot the error. A few people on the dev team have AUAV-X2 boards so we should be able to test and include in -rc9 and/or a patched -rc8 so you can test.
Thanks for the report!
Randy,
i made a short test with my AUAV-X2 and -rc8:
LogWhenDisarmed = ENABLED
When powered over USB the log gives a 5 on Powr/Flags.
When powered with battery the log gives a 7 on Powr/Flags.
That means, the Bit for USB_CONNECTED is always 1.
It seems, the problem is NOT solved...
I still saw same compass variance error trying to "fly by hand" with rc8. Also note hdop 0 issue - but, even with it, little drone behaved way better now than with rc7.
Hi DG,
the issue seems to be solved.
Cheers,
Thorsten
OK, it does not seem to be so.
is the 'Connected=True' message in the MP status window referring to USB connection specifically?
mine is not connected to USB and it stays as 'true'.
What is expected from
return stm32_gpioread(GPIO_OTGFS_VBUS) && stat("/dev/ttyACM0", &st) == 0;
this to happen? what is the 'stat("/dev/ttyACM0",'? Does it need any hardware modification on the AUAV board or not?
if it matters or no, here are start messages from MP, below. Was it expected to identify AUAV in there somehow?
APM:Copter V3.3-rc8 (818ef282)
PX4: b0cb142b NuttX: d447403a
Frame: QUAD
PX4v2 0025002A 3333470F 39323135
PreArm: Need 3D Fix
