Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Randy,
          Thanks for the explanation. I understood about Note #1, I wasn't concerned with the number per say, it was really the fact that I got it almost immediately upon powering up while I was indoors! That seems very unlikely.
          Any clarification on the units that the sonar values are when reported on the Mission Planner status tab? Or the pitch oscillation I'm seeing when I reach the value of WPNAV_LOIT_SPEED?
          Thanks,
          Nathaniel ~KD2DEY
    • Yeah I autotuned roll and pitch axis with rc8 yesterday with aggressiveness set to 0.5.  Roll axis is OK but pitch axis took forever to autotune and now I get slow oscillation on the pitch axis when it recovers from significant pitch movements.  I'm going to re-autotune today with 0.7aggr and see what happens.
        Hi Fnoop,
        0.5 is way too high, that will be limited internally to 0.2. I hope you meant 0.05 but it is worth checking you didn't make a mistake.
        My suggested range is 0.05 to 0.1.
  • Has anyone else had trouble geotagging gopro pics via mission planner with 3.3rc8? Works well with 3.2 for me. When I tried with 3.3, using time offset, est offset always shows -1, then pre processing finds no matches. 3.3rc8 log below.
    2015-07-30 16-45-21.bin
  • Randy, maybe it will appeal to you to compile something like 3.2.2 with most of the 3.3's non flight control related features like different gimbal serial  support, retracts and some other kinks? I think it is beneficial for both the AC project and us is users as we'll get some useful features on a hell of a stable platform, while you guys will get a chance to iron out any bugs in the said non flight control related features at the same time you will get some more time to work on the EKF and make 3.3 something really great instead.
  • Hello,
    Is this negative baro readings are ok in flight?
    3702059229?profile=original
      Yes, that just means that the baro thinks it's below the home altitude.  The baro suffers from drift (a natural consequence of the type of sensor) so it's possible to see negative numbers even when it's not below the home altitude.
      This looks like a very sudden drop, I can't see the logs but I'd guess that it's an aerodynamic effect caused by the vehicle moving.
      • Thanks for the answer, logs also have disarmed logs. During the flight one prop sliced receiver antenna so i landed for check. But still althold mode altitude drift. My copter still lost altitude but giving more throttle overrides. On previous versions full throttle doesnt any effect and copter lose altitude until it lands.
        If you still review the logs its here:
        https://www.dropbox.com/s/rxd5rpucu2av5iv/7.BIN?dl=0
        7.BIN
        Shared with Dropbox
  • Dear Reader
    I don't really know where to post this question and if wrongly posted I hope a civilized moderator will transfer it to its correct place. Thank you. Now to my question:
    As impressed as most people are by fascinating radio-controlled flying sauces, I am equally surprised over the design capabilities of some individuals. Taking a passed away dog used for hunting many years and making a set of gloves out of its skin in memory of it is one thing, but to turn a dead cat into a drone... Is that ethical?
    Frankly, what do you think?
    The cat forums are raving about it, so left is to know what the drone community thinks. After all, where is the moral in this if God created us? Shouldn't also a cat deserve a nice funeral the same way as us humans.
    This is what I found:
    https://www.youtube.com/watch?v=S8QWMatuiWw
    /Kalle
    YouTube
