Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Thanks for testing.
      The MP still needs to be updated a bit more to match the parameter name changes for AC3.3.  I'll remind Michael so hopefully he'll get to it soon.
      The AutoTune takes more time because it does Yaw now as well.  The AutoTune wiki page has new instructions to allow tuning a reduced set.  For the next release (AC3.4) we will likely add a better autotune interface to the ground stations to make this easier.
  • "HDOP values will appear about 40% lower than previously but this does not actually mean the GPS position is better than before."
    Does this mean GPS_HDOP_GOOD should be set to 230-92=138 or is it just a display issue in 'Flight Data' ?
    • The new default is 140, so you should set it to something like that if you are still seeing 230. 230 is now too high for true HDOP, was ok for PDOP. The 140 figure comes from Randy comparing before and after and scaling 230 appropriately, so I don't think anyone really knows if 140 is the "Right" value, but its a lot more right than 230!
      • Thanks Andy,
        Indeed the value should be lower then the original 230..., so reduced to 140, which doesn't prevent arming, and is allowing me to take off in Loiter.
        Did see the fast flashing green indicator as well, so is fine during flight..
    • Be careful with this setting for HDOP_GOOD, if you activate geofence you will see what factual HDOP and number of satellites it accepts as 'good' until it will finally let drone to arm.
      I do suspect a lot of subsequent EKF issues that were reported here may be related to GPS units not yet hooked up to sats at the level that geofence logic assumes to be a good '3D fix'. This '3D fix' level does not seem to correlate at all with what I used to presume as a 'good' HDOP level. It is way, way lower, in the new HDOP values it goes to 12-14 sats and HDOP of 0.90 or something like that. But it flies pretty stable after that.
      • By my undestanding: if your GPS HDOP value drops below the HDOP_GOOD value, you are fine flying any GPS assisted flight modes, and Geofence is acting on a breach as well.
        Bringing this value lower, like 0.90 makes it harder to reach for those GPS units which are not capable of locking 12-14 satellites, like the NEO-M8N which I do use.
        With the new code RC8 the valid question is should you move the default of 230 to something lower, like ultrafuge is suggesting, to maintain the same security level as before with the 230 ?
        I originally brought it down to 140, as well but then it took quite some time to reach the usual OK to fly which I interpret by getting a green light on the PixHawk, so I did bring it back to 230, but that might actually be too high in this new scenario.
        • 3702794282?profile=original@ Erik Groeneveld : NEO-8M and RC8 lock 18 sat without problem (see the short attached bin file).
          Henri
          2015-08-01 11-27-26.bin
          • Thanks Henri, I do see the same figures with my Neo-8M, so reduced the HDOP value to 140 on both birds!
