Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I've got two copters with them now. One is from HK, and the other is from readytoflyquads. The mini M8Nv2.
HK gets a few more sats, but I think that's due to the layout of my copter (650 vs 250).
Both have the same behavior. Great in the clear sky, but jumps around more than previous GPS when lower to the ground.
It's raining now, so probably not a good time to get a log.. But, I can certainly make one. I simply have to arm it outside and let it sit stationary, and we can see MP thinks it's drifting all over.
I'm not all that concerned, since it's ok high in the air. Maybe I'm expecting too much, and am unlucky that my flying/testing ground has a few trees.
I've had very good results with the M8N on both a copter (3.3 rc5) and a fixed wing (3.3.0). My quad loiters with (at max) a 50cm drift in any direction.
I have experienced the drift you describe above, but only when I've been inside or amongst tall buildings (both times the quad stationary and on the ground), but I attribute this to not having a clear view of the sky for the antenna.
Well, I should have been more clear in my description..
Or at least added, the copter is very still when it is up above the trees. I don't notice much drift at all. But, down among the trees with a patchy view of the sky, I still have over 15 satellites and a low HDOP, (below 2 with the old pre rc8 hdop numbers) but the copter drifts all over as I described.
The old copter with lea-6 didn't drift as much in the same location, with fewer sats and higher hdop.. Sparsely wooded.. Clear sky directly above, but trees nearby.. spaced apart enough to comfortably fly around them.
that is why a best design is to use 2 GPS devices and use 1 m8n and one lea-6 on the same vehicle.
As Randy stated an effort will apparently take place to minimize position adjustment when one GPS switches with an another dynamically. As of 'jumping' coordinate from same single GPS - it is a different issue, probably.
Hey Randy thanks for looking it up. We also found the "step" in the logs with our analysis. As nobody replied here the discussion and possible reasons are being discussed in a Navio's forum thread.
The build was from the DIYdrones website with the normal image and a custom launch script. The current hypothesis is that 2 instances of the the executable were running at the same time in our setup thus causing some kind of weird race, although in previous versions I have tested this could not happen even if we tried.
Unfortunately my card got corrupted and I cannot recover it until September. If we have more news and the Emlid forum thread progresses I will update this mini thread.
Also, can I add a timing glitch check to your LogAnalizer script so that it checks for this condition in the future?
Thank you for your help
Paulo Neves
Roll came out close to what it did with 3.2, but Pitch was over aggressive- osilating with sharp stick movements. Yaw turned out well also.
[URL=http://s1239.photobucket.com/user/86burbguy/media/Mobile%20Uploads/6EAEA882-88ED-4E84-90D7-AA2F68FA8BB1.png.jpeg.html][IMG]http://i1239.photobucket.com/albums/ff502/86burbguy/Mobile%20Upload...[/IMG][/URL]
Given that Pitch value is more than twice the normal limit, even the Roll axis which is tuned nicely is over normal limits, I am stuck going through the full parameter tree or rerunning the auto tune.
It would be nice to see the tuning limits expanded or more easily orveridable than they are right now.
Hi Wes,
I would suggest doing just your pitch tune again. Make sure AGGR is set to 0.05.
Hi Greg,
It definitely looks like it rolled to the right and pitched up before you hit the ground suggesting the right rear motor gave out.
What motor smoked?
Hi Greg,
I like people to log 157693.
Yes, coming in hot will defiantly cause it to pitch back. The pitch is much less obvious than the roll and that confused me a little. So what you says makes sense.
Sorry to hear about your crash!!
210
211
212
213
214
of 449 Next
