Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Randy,
I looked at the radio logs, and it doesn't seem to be anything related to radio inputs, as it can also be seen from the TLOGs.
My biggest issue now is to sort out the THR_VALUE for the failsafe....
Ah,
something else Randy.
Bunny hopping on land still here :)
Luis,
Really we need to see logs but I strongly suspect this is a ground-effect-on-baro issue. The Solo suffers from the same thing and you can see how it lands near the end of this video. Solo-master has a work-around for this that we may add to Copter-3.4 but we need to review it and ensure it doesn't mess things up for other users. If this is indeed the issue, then I think it will show up clearly as baro movement during landing and a physical change to the frame is probably the only viable solution in the short-term.
Just a positive reflection:
Two examples with Land (last 7 seconds of the Video).
https://www.youtube.com/watch?v=TYaxE3_TuLc&feature=youtu.be
https://www.youtube.com/watch?v=Ez16y-yep_M&feature=youtu.behtt...
No bouncing @ all. Btw., all Settings @ Quad Default , no autotune. Since I do a lot of flights at 1-2 m height, I don´t believe in ground effect issues.
I´m always using LAND (coming usually from PosHold) and it works perfectly with -rc10,-rc11 with AUAV-X2 ,Pixhack (with internal damping) @F450 and the Pixhawk Lite cheapo @ Mini Drones 500mm Carbon Frame.
PS: What I like about it,that the throttle hasn´t to be moved down
Thanks a lot for the good work !
If I get some time today, I'll try to get video of the bunny hopping :) but don't consider it as a serious issue. The "hopping" I'm seeing on this small 330 quad is way less pronounced that the one you have on that Solo video.
I'll have a look at the logs I linked to check the Baro behavior.
Randy, where is it possible to get list of all current messages codes now and WAV files that accommodate those messages?
I use Taranis LUA script to speak up that info and last 3.3 rc builds got way more messages than old 3.2.1 used to have, so it has to be synced up.
I'll update the wiki with all the pre-arm messages. thanks for the reminder!
As I've written on other thread before, after 3.3 is released the entire code must be grepped for the strings, as it has been done before for 3.2.1
Hi Paul,
please, can you share a litle more your hardware and software to use Taranis (LUA) for telemetry ?
thanks a lot
Sure, it is in my opinion a #1 thing to do for any Taranis owner.
This thread
http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
and this video
https://www.youtube.com/watch?v=xWRNhiJ1BNk
has all the info.
Essentially you will feed standard telemetry into a Teensy board that is connected back to X8R that will send it all back into Taranis. On Taranis you run a specific LUA script that gives you all required data and 'speaks' all important messages to you. That was a core of my question as I need to sync up those messages now somehow and not sure if anybody looked at that yet.
155
156
157
158
159
of 449 Next
