Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • update: Motor was missing one magnet! So most likely problem solved. New motor it is.
      • Well, that was pretty accurate analyzis. Got the problem again, but this time better pids and no gimbal, I was able to control the thing and saw clearly that motor 5 was the problem, it almost stopped. Any idea what could cause motor malfunction? Magnets? bearing? esc? Motor or esc are not hot, maybe little warm only. Bearings doesn't seem that bad at least compared to others. These things seems quite hard to "debug"..
        Again, after that I was able to fly normally and did autotune. Tried to land in althold, landing was not recognized correctly and copter flipped.. Did read later posts about the same behavior. Hopefully landing will be tuned better in future.
        • VP, just curious. Were you able to control the Hex with one failing motor? Was it bad? How much thrust you need to hover?
          • Not really well. It tilted hard when motor failed. Of course I was kind of expecting the failure so I was flying really low. Couldn't land it on it's feet, always fell. I think if the hex was higher, it would have been possible to take better control.
    • i had almost exact problem before and it was driving me nutz...eventually i found out it was a motor going bad and having sync issues....it was very hard to figure it out....but check your motors/ESC for intermittent failures
      • May I ask how did you eventually figure it out? Motors twitched or stopped? I have not noticed any of that. Were you able to solve that using logs somehow? Was the problem random or repeatable?
        I don't get it as it flies nicely on the second try. It has always been the first flight that causes problems. I took the gimbal off and will test again today.
  • I found some smaller issues with RC10:
    • RC deadzone settings don´t work for the serial RC control channels of the storm32 gimbal (RC6).
    • Sonar height differs after some flight time out of sonar range to the est. height. That leads to jumpy alt behavior commng back to sonar range.
    https://www.dropbox.com/sh/dnarxid3xychq1u/AADKFswaADCzTSE_uCl6Eupq...
    There is another autotune log in the folder.Maybe someone could give me a hint how to get lower PI values from autotune? Maybe it is possible to lower the autotune_aggr below 0,05?
    It´s a large Tarot T960 with 18" CF and 5010 pancake motors. The auw is about 6.x kg.
    Cheers
    Gregor
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Hi Gregmaan,
      0.05 is the lowest it goes. What exactly is your problem with the tune?
      • Hi Leonardt,
        my problem is still that the copter still reacts too much in windy conditions.
        With aggr of 0.06 the problem gets worse.
        This happens either in stab and loiter/pos_hold.
        This is an old case. Last time with lower RCs you told me that I should reduce some filters from 20 to 10 Hz (because of high frequency vibs at about 20 Hz.)
        But with RC10 and above this does not give the results as before.
        Maybe you can give me a hint? Does I still have the vibs at 20Hz? How can I visualize these vibs?
        Thanks a lot, and sorry for my poor english ;-(
        Gregor
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
