Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • yea i have a micro pixhawk called pixfalcon micro from hobby king on a 250 i uploaded rc11 and everything went nuts on mission planner the horizon thing was spinning around in circles everything was on acid... went back to 3.2.1 everything was fine  weird.. rc11 3.3 is just well nuts
        • I have deinstalled MP and re-installed ( running the MSI as administrator with a registry tweak ) trying to get the beta releases I still get a 403 from the servers when trying to download the update. Can anyone point me to the beta builds of the files that I can use or a list of files that comprise the beta upgrades.
        • T3
          Captain,
          hell of a lot of nuts around...
          I am pretty sure that AC3.3rc11 is not to blame if AC 3.2.1 is running fine. Your copter should fly better with AC3.3rc11
          But, have you gone through all the calibration steps again?
          Best regards,
          Thorsten
          • um no rc11 is to blame.. didnt do it on 3.2.1 the official release.. when i went back it was fine so it was the beta... dont forget im a captain and been flying helis for 20years now.. but this new tech is all software based.. to many sensors to many things to mess up.. before you had to actually know how to fly with this stuff its point and click..
              James,
              Where exactly do you think AC 3.2.1 came from, another planet perhaps? It came from the same developers working on this release.
              What Thorsten was asking you, which by the way you didn't answer, was if you had followed all the directions at the top of the page, you know the ones in bold red type warning you of impending doom if you don't do certain things like re-calibrate your accelerometers when upgrading from AC3.2.1? If you didn't then go back and follow the directions. I think you will find it makes a world of difference.
              Live long and prosper,
              Nathaniel ~KD2DEY
              • spock calibrated it for me... yes of course i did.. but for some reason it seemed like a drunk uncle that just got bad news that nascar isnt going to be around no more and his favorite beer is going outta business..
                but seriously once i went back to the stable release no problems...
      • ian,
        Make sure you are in the "Administrator" account when you do the MP upgrade. You may also need to turn off your virus checker when upgrading to the MP Beta release, others have problems with it. See this link: http://diydrones.com/forum/topics/mission-planner-for-windows-10?xg...
        • +1 on that advice - On Windows machines, always right-click and 'run as administrator' as well as suspend / disable any real-time virus scanning.
          • Thanks Phil, Kurt. Unfortunately that didn't fix it. I'm getting a 403 error from the server during the download of the dll.
  • I was wondering if this a new change that was meant to be there. In 3.2.1 using tower you could switch to Auto and without moving the throttle the copter would take off and fly its mission with out touching the R/C controller. I am trying 3.3RC11 and now in tower I switch to auto in Tower and I need to move the throttle to make the copter fly. Is this a setting I need to change or is this the way it is suppose to be for now?
    Thanks and Great work. Very smooth....
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
