Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Hi Randy,
        I'd greatly appreciate it. What I notice is a very noisy IPD which looks to be caused by a very noisy baro. At least in comparison to the wiki.
        Using the 3.3 vibration tool it looks like my vibrations are acceptable.
        Here's the .log:
        https://www.dropbox.com/s/xk2klyey5tjc54m/2015-12-02%2016-28-17.log...
        Dropbox - Link not found
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
        • yes, your vibs looks good, It's look different than my vibes problem
    • Kenneth: I had the same issue with vibs under acceptable levels during long time but vibes were my problem at the end, be shure that isn't the problem.
      • Sloppy motor bells can also cause some of these issues.
        • I'll relook at vibrations. I've been using the Copter 3.3 Vibration tool in mission planner. I'd assume that motor bell slop would show up as vibration.
          • It would and mostly the Z axis
    • did you foam the baro? Yes even with it in a case and yes even with the RCTimer AVDome. I had similar issues with one of my hawks and it too was in an AVDome and some dense foam and a recalibration did wonders.
      Also did you make sure to adjust Hover_Throttle to match exactly what your STAB hover is in mission planner?
      BTW Tlogs are pretty worthless. You need to attach an actual .LOG/.Bin that you download from your Hawk.
      • It is a 3DR manufactured Pixhawk. Opening it up and adding additional foam was my next idea. It remains in the 3DR case under the dome.
        How do you recalibrate the barometer?
        • I think it does that itself at every reboot.
        • I meant ACC and MAG as I don't know of any way to calibrate the baro.
