Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Pomaroli,
What have you set Autotune_AGGR set to. You may want to drop it to 0.05 and try again.
You may be able to get away with setting the Accel values up to 2x the autotune values before you start to see bounce back after it reaches the desired point. I personally use the results of auto tune because it gives me a little head room on the motors when I get aggressive.
Acro_yaw_p defines the maximum rotation rate ( x 45deg/s) and Accel values define the acceleration.
Leonard, what copter did you use for testing quad or hexa ? my Hexa is far away from this values. it's starts to bounce back much earlier.
For Yaw PID i get something like
I = 1
P = 0.1
I = 0.8
P = 0.08Hi Pomaroli,
Sorry, it isn't very clear what you are asking but I will do my best.
I said you may be able to go as much as x2 the accel values but you may not be able to go any higher. This depends on exactly how you are flying your copter and what your hover throttle is. As I said, I don't recommend increasing the Accel values over the ones given by Autotune.
Your PID numbers are confusing. It looks like you have P and I reversed. Assuming that is the case did you get those using autotune and if so what is your Autotune_AGGR set to?
The values of Accel_Yaw_Max and Accel_P really depend on your personal preference. I agree that there is a nice ratio that will feel right for most pilots. Accel_P = 0.3 * Accel_Yaw_Max / 4500 is what I think is a good ratio for me.
I don't understand the last sentence.
Hi Leonard,
i can't go x2 in accel Yaw because it starts to bounce back or otherwise i'm not understandig what you're saying. The Hover Throttle is very low about 220, so what does this mean ?
yes you're right the numbers are reversed, sorry for that. This values are made by autotune. I already tested by lowering AGGR which results overall in lower PID, but did not solve my yaw oscilation problem. As wrote before if i'm starting autotune from default value i'm getting the "good" YAW PID and by re-doing autotune from the already tuned values i'm getting higher YAW pid's which will lead the vehicle to oscilate in yaw.
The oscilation in yaw is very low when in hover but higher when flying around.
Thanks for the ratio tip, but i'm not getting it, here my example :
ATC_ACCEL_P_MAX,95925.84
ATC_ACCEL_R_MAX,93156.18
ATC_ACCEL_Y_MAX,26500.99
so Accel_P = 0.3*26500/4500 = 1.7666 ??
Is there also an ration between acro_yaw_p and Accel_Yaw_Max ?
Hi Pomaroli,
I mean it will start to bounce back between x1 and x2. Most people will back the ACCEL numbers back off to x0.5 or x0.75 to get the feel they like.
Normally you will start to see some bounce before you get to x1.5.
Your ATC_ACCEL_Y_MAX is very low but your calculation is correct.
Can you give me logs, one from the initial values and one from the tuned values.
Sorry, I meant to say.
The values of Accel_Yaw_Max and acro_yaw_p really depend on your personal preference. I agree that there is a nice ratio that will feel right for most pilots. acro_yaw_p = 0.3 * Accel_Yaw_Max / 4500 is what I think is a good ratio for me.
you're welcome leonard and sorry for my poor english sometimes.
Leonard,
here the logs Logs
i've done first Pitch and Roll wich came out very nicely, then Yaw from default and third run the recalibration of yaw.
Hi Pomaroli,
Sorry but that isn't the autotune logs.
Hi Pomaroli,
Well, this may be caused by the flexing of the frame but I am coming up empty. The only thing I can suggest trying ti setting Autotune_Aggr to 0.05. However, if you are happy with the tune you have now I would just relax and enjoy flying the copter.
Sorry I can't help more. I will keep an eye out for similar issues with other copters and see if I can work out what is happening.
Thanks for taking the time to give this feedback!!
Hi Leonard,
sure here are some pics
This pic is from the build off, in the meanwhile i replaced the pixhawk mount with the other type usually offered on the marked which has the flat plates with 4 holes for the rubbers.
This is main view, the copter i perfectly balanced, the weight focus is in the Middle
