Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • @Dave, an intelligent FFT analysis algorithm can self match sampling rate since samples can be approximated by continuous sinus/cosinus functions Infrasonic vibrations can be generated within very small cavities due to Helmholtz resonance (Holmholtz resonator)
              • longer reply has been already cut three times
                just email me to get full reply
                darius
                manta103g@gmail.com
        • I've always used a pixhawk on the two plate with rubber-thingees mount which has always worked great.  I then tried the hobbyking orange foam that the wiki suggests and it was a complete disaster for me - I got all sorts of barely recoverable control issues even in stabilise mode, so I went back to the two plate mount and worked perfectly again.  If you're getting high vibes it will certainly affect stabilise mode and it's a complicated subject with no single answer, so if you're having problems then try a different solution until you find one that works.  If you're getting clipping and high vibes then fix this first as it will always make your flights unstable, gps is largely irrelevent at this stage.
          • Thanks for your answer.
            I have these mounting pads and thought of switching to the orange latex foam. But as this didn't work for you, I am afraid it won't help in my situation either..
            The two plate mounting solution is no option for me because i want the FC to sit between the sandwich plates and there is not enough space for this mount.
            I may have to test my motors maybe, as I already balanced my props.
            • Dave: I try many things and solve with this  http://www.hobbyking.com/hobbyking/store/__76727__APM_Flight_Contro...
            • Aargh this braindead forum software bit my post in half again..
              The best of all I found was the original foam that comes with the pixhawk but it's difficult to find/get other than 3dr (which is not feasible outside of US).  If your X and Y vibes are OK then your motor/prop balance is probably OK so just try different density foam mounts and see if your Z vibes drop - at least below clipping levels as that's what seems to really upset the autopilot.  It's also worth looking to see if you have any bell play in the motors as that shows up with high Z vibes - see if you can find an excellent post on this subject by leonard if you can find it with this ridiculous antiquated forum software. If you'd missed it, I'm not a fan of this forum software.
              • yeah, this software is a bit strange, I agree.
                Okay, maybe I should try Moon Gel pads..
                I will look into this and try to improve the z vibes before I fly the next time, thanks!
              • ps - I wouldn't bother looking into ekf/gps or anything more complex until you've got vibes under control, so fundamental are they to stable level flight.  In hundreds and hundreds of flights with lots of different hardware with this awesome software I've only ever had unreliable behaviour due to vibes.
    • Hi Dave
      You're probably better off asking here:
      http://ardupilot.com/forum/viewforum.php?f=111
      or here:
      http://ardupilot.com/forum/viewforum.php?f=80
      This thread was for beta testing of the 3.3 code which is long over, even though in the last week or two it even seems to have expanded to general 3.2 and 3.4 questions..
      • somehow, I don't receive the activation mail :(
