Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Thanks I thought it might be on limits of the motor and props don't really want to go any more power or I'd loose flight time
            Stuart
        • My setup
          17x5.5inch props
          390kv motors
          30amp Simonk afro esc
          10000mah 4s
          Pixhawk 2.4.6
          Flys for half an hr
        • vibration levels abit high but there was a 23mph gust winds
          vibration within normal levels on not so windy days
          stu
      • Will do but hopefully tomoz as is 11.10at night here lol so if it's not raining I'll try tomorrow cheers stuart
    • sorry missread where you said you covered the entire hawk in cling wrap and not just the baro :(
    • you should NEVER cover the holes on the baro. Use dense foam not cling wrap.
      • Hi yes there is dense foam over the barometer in the pixhawk case
        Stuart
        • What Craig is getting at is that you said you cover the whole pixhawk in cling film, which is essentially the same as covering the holes on the barometer rendering it useless.
          • Oh sorry no I only covered with cling film over the top to stop wind blowing in directly it was no where near air tight or all around
            I still got height reading on mission planer
            Cheers stuart
  • I have done about a dozen flights now with V3.3 on my littlest Pix, a 320_mm hexacopter.  I had a few issues with the Autotune and PIDs on upgrade, but this thread has helped me sort those out.  Thanks boyz.  I have been pretty satisfied with V3.3
    But, today I have landing gear and a bent arm to repair. On my last flight, it inexplicably dropped from the sky.  I have tried to decipher the cause from my logs, but I don't have the experience to determine the issue. It felt like a voltage drop, but the battery had over 11_V remaining and the cells are within .1_V of each other.
    Can anybody suggest the culprit? . . .
    2015-11-06 17-21-17.log
    https://storage.ning.com/topology/rest/1.0/file/get/3702120584?profile=original
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Saturday
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
