Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It is not m8n. I use a Novatel module that outputs either NMEA or Novatel native messages.
When you upgraded did you happen to go to full or tree then GPS1 and set it to NMEA?
Yes, tried to set the GPS type to NMEA. But this does not help.
what happens if you flash it back to 3.2.1?
When I flash it back to 3.2.1, the GPS works. MP shows "3D Fix" again.
Hi Craig,
More tests shows that this regression appeared since this build :
http://firmware.diydrones.com/Copter/2015-07/2015-07-20-01:07/
This corresponds to the commit the same day:
https://github.com/diydrones/ardupilot/commits/Copter-3.3?page=16
I see there were 2 changes regarding to NMEA GPS.
Hope this helps,
These changes introduced a delay (negative or positive) between _last_GPRMC_ms and state.last_gps_time_ms. This delay depends on the baud rate, and also probable depends on the order of the messages.
Hi Speedy,
Your vibrations are pretty high. Large props into the wind can vibrate a fair amount especially if the frame is flexible. Your tune doesn't look like it is causing the problem though.
Hulk: Try to repeat pitch autotune or try to reduce it manually, thats in part your wobbles ccd and other problem is that if your camera wobbles probably isn't ccd, it's cmos, are you shure?
Yes, a wonderfull weekend here ;) .....but I'm not have with me my copter :(
If it's an Alien 680 frame, I have one too and am having problems getting it tuned. From what I've heard many do. Everything is tight and COG good. AT was done with AGGR at .07. The copter is not stable after 2 AT's.
My PID's are quite different than yours. I'm starting to think I need to put some good CF props on this bird. With the cheap Gemfan CF VIBE's were lower, but over 500g thrust I don't use them. Currently it has APC MR 13x5.5 and it just doesn't seem to be as responsive plus does wobble.
I've never had a quad with these goofy PID's.
74
75
76
77
78
of 449 Next
