Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • I think Randy mentioned that if you had a 3 position switch, middlepoint was some sort
          of auto, but what it do i have no clue. Havent tried yet
  • Hi
    ublox GPS is not detected when i tried 3.3 rc5 on px4fmu+px4io. Works ok on ac3.2.1 though.
    used 3dr GPS + compass and quanum GPS + compass both not detected on 3.3 rc5 but detected on version 3.2.1
  • Yesterday I flashed the V3.3-rc5 to my PixHawk hexacopter, but now I can't get to download the log anymore.
    In the MissionPlanners (latest version 1.3.28) CLI it only gives "mumbo jumbo".
    In the beginning it says:
    Waiting for reboot
    Opened com port
    3Initialising APM...5? (NO mention of Arducopter 3.3-rc5)
    Then the mumbo jumbo starts.....
    What am i doing wrong?
    btw Arducopter V3.2.1 gave no problems.
    • Paul,
      Download the Log via Mission Planner Terminal does not work anymoe from 3.2 and upwards.
      In Mission Planner go to FLIGHT DATA and sellect "DataFlash Logs" under the HUD screen.
      Than click "Download DataFlash Log Via Mavlink".
      Hope this helps.
      • Geert is correct but I didn't understand how Paul said " Arducopter V3.2.1 gave no problems"!..
        The last release version that used the terminal to download the logs were 3.1.5. Terminal removed after that.
        AC 3.2.1 should be same as AC 3.3 rc5 as far as the log download is concern.
  • anyone tried out storm32 and tower at same time ?
    my tower goes crazy ...
    https://youtu.be/KzHd5ndXE84
    • It's probably because tower is picking up all the mavlink messages from the storm32 and not filtering them out.  If tower has an option for specifying a particular system id and component id then try setting them to 1 and 1, if not then it probably needs a bug/issue filed against it.
      I had the same problem with teensy telemetry and had to recode it to only listen to mavlink messages from a specific system/component id.
  • In the full parameters list the options for setting serial 4 protocol and baud are missing even though the second GPS parameters are included. When will the serial 4/5 parameters be added back to enable secondary GPS module use? Or is there another way to enable this that I am unaware of?
    A second GPS is critical for UAV Outback Challenge operations, especially on small copter frames where RF separation is difficult.
    Regards
    JB
  • Autotune 3.3 rc5: frame x8 motor U5  propellers 16"+17" weight 9 kg (4 autotune, 4 different results)3702016681?profile=original
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
