Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • What happens if you apply 5V from a BEC to your landing gear while the signal wire is disconnected ?
          • Nothing happens.
          • if you are using Tarot medium and large landing gear you can very well fry your landing gear controller, lookup on rcg I've posted couple of pics where power protection circuit is untouched, while the microcontroller chip is fried.
            • I'm using X-Cam X6 original landing Gear. By KongKopter.
            • Hi all
              and thank you for great job in 3.3.2
              I connected the signal wire to Aux1 (pixhwak) from tarot retract and the ground and 5v to voltage regulator. the result is in the follow video
              https://www.youtube.com/watch?v=gZSSq6pkSos
              • I can not obtain the same result.
                Of course if I switch the CH7 I can open and close the landing gear at command.
                This is not a problem.
                The real problem is that when I switch on the PixHawk, PixHawk command the Landing Gear to Open.
                So PixHawk have an High PWM signal at the startup.
                Is this possibile?
                • Yes for servo deploy. That means that landing gear is open in start before flight.
                  Look this page: http://copter.ardupilot.com/wiki/landing-gear/.
                  Then look the values in this channel(from mission planner radio controller) that use for landing gear and change properly . For fail safe decrease this values .(ex. from 1750 to 1700) .
            • That's good to know. The only thing holding me back has been the extra weight, but hear many stories of the LG failing.
          • It depends on your landing gear controller, but hopefully nothing happens.
            • That's right. In my case nothing happens.
