Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Craig,
      Sorry about you crash.  Txs for the suggestion on the pre-arm check of the servo rail voltage, I think we can add a servo rail high voltage check fairly easily (a low voltage check would be difficult because many users leave it unpowered).  5.6V seems about right?  Our main board voltage check is 4.3V ~ 5.8V but maybe we should tighten these.
      The in-air voltage check is something we've discussed a few times but haven't implemented because we thought that it wouldn't help much because when the power system goes bad, it goes bad quickly and there's little warning.
      • What if I am running 6v on the servo rails on a traditional heli. But the PixHawk is powered by the PM? Would this cause issue?
          UAS_Pilot,
          As long as the vehicle is powered through the power module then it should be fine.  It's only if you want a backup power supply through the real power rail that it's important to ensure that back power rail is less than 6V.
          If we add a pre-arm check that the real power-rail is under 5.8V though then you would need to disable that check.  We haven't added it yet though.
          • Ok.
      • Maybe have a quick look at my flight log. Make sure I am correct as to the cause of this crash. I dont want to rebuild this thing in generally the same manor thinking I have nailed down the cause of the crash just to have it crash on me again.
        thanks in advance!
        4.BIN
          It looks like a brownout in that the logs just suddenly stop.  We don't actually have a way to distinguish brown-outs from catastrophic firmware failures although we're working on a way... but normally when the logs just end like this it's a brownout in these cases and the board voltage is indeed very high at 5.7+ volts.
          I think Jesus is correct when he says it will fall back to the power module if the power rail voltage goes too high.  Maybe you weren't using a power module?
          • No i was  not using a power module. I am running 12S, so i have the 180A atto pilot in there. but without a bec on the 5v and gnd wires to the pwr module port.
  • Here is the flight log. failure mode (drift) is in first flight. Video of the flight here. Thank you.
    log alien 1.rar
  • This reply was deleted.
      Someone else made that suggestion as well.  Personally I think the differences between AC3.2.1 and AC3.3 are not so large that it deserves the major version number increase.  For the APM boards, if we do a patch release we will call it AC3.2.2, AC3.2.3, etc so only the last (most minor) number would be increased.  We wouldn't call it AC3.3.
        Dropping the 8 bit support is not a good reason for a major revision number change.
