Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I use some pads from hobbyking. Don't know the name. Actually, I did 2 test, with and without pads. Same result. Pixhawk fixed on place and does not touch anything. Vibrations spikes looks very constant and does not seems like ordinary vibration. Have no idea what to check next.
  • Thanks for looking Paul. What should I be looking at hardware wise? How can I shield the GPS from jamming?
  • 3701994504?profile=originalCan some one explain, why I get constant spikes. My Pixhawk on soft pads, so it should not be vibration. Have attached full logs, where I test 3.3rc3 ... Have a very bad waiving at the middle of the flight.
    2015-05-04 16-16-43.bin
      Andrei,
      We've seen these "whiskers" in a few logs including on one of my IRISs.  They only appear on the MPU6k accelerometers and only on AC3.3 (i.e. not on AC3.2.1).  There's a growing sense in the dev team that we've got either a software bug or a weird physical effect.  We're going to need to get to the bottom of this issue before we release AC3.3.
      Thanks for these logs.
      • Randy, thanks for reply. I'll try to switch to 3.2.1 and test again same frame, same hardware. Now 3.3rc3 flies not so good for me. I get huge waves (like out of control) when I want to rotate (normal or fast yaw). Also on Alt-Hold I got little jerking up-down-left-right - also looks like out of control.
    • I'd say something is loose due to all 3 axes exhibiting vibration same order harmonics, also high Z compass offset. Note high RCout as well.
  • This morning I tested 3.3-rc3 in Guided mode for the first time.  I used dronekit-python and an Iris+.  I was able to arm and takeoff, however, despite giving an altitude of 5m in the takeoff command, the Iris climbed to only about 10cm.  On a second attempt, it climbed to about 1m.
    We then reverted to 3.2.1 and ran the same script.  During takeoff, it climbed to ~5m as instructed (and as it always had before when testing).
    Any ideas why it isn't climbing properly using 3.3-rc3?  I should mention that all three tests were done in the same location with a clear view of the sky and large numbers of sats.
    Our need for 3.3-rc3 at the moment is the SET_POSITION_TARGET_LOCAL_NED message which isn't supported in 3.2.1.  We would really like to get this figured out so we can move on with our project.
    Thanks for any insights.
      David,
      I'll answer this over on the drones-discuss or gitter threads 'cuz you've posted there as well and it's really more of a developer question,
      • Randy, et.al., We are experiencing same rc3 issue. Lawnmower mode. :) Looked at drone discuss and gitter, cannot find the discussion. Note we are using Lidar Lite but not flow, we did not do the Lidar prearm because we thought it only applied to flow. Any hints? Thanks!
        Mike
  • Parachute function test results 1:
    I uploaded latest 3.3 RC3 to Pixhawk and setup parachute to use servo and altitude check is disabled.
    Sometimes I receive "altitude: too low" message and sometimes parachute is ejected. I noticed that if throttle is carefully raised, altitude too low message appears. But if throttle is raised fast, is parachute ejected. Throttle position doesn't seem to do any difference, only how aggressively throttle is raised matters. On another test attempt I received only too low messages and couldn't eject.
    Any idea why eject altitude check is inconsistent?
    I have a video to be uploaded if it helps. Terminal doesn't want to connect Pixhawk and therefore logs are not available. MP is 1.3.25.
