Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
These kind of systems will even get cheaper. One day everybody will be able to afford some brand or another.
I remember the systems like Micropilot, Hellicomand Profi/GPS and as such years ago when these systems were just coming onto the market. Each system was costing a fortune. Lol...
All good things come to an end ...Pixhawk 1 or 2 shopping time.
Sure. It would be nice to know the Pixhawk's shelf life before making a purchase.
My APM 2.5's usable life was less than 2 years and that is with adding an external compass and some other improvements to keep it current.
Yes, it is still running and usable but now will no longer be a current FC sadly.
2 years is an eternity when it comes to these things. I think you should count your lucky stars that you GOT 2 years out of them, I know I do and am quite content to keep the ones I still have on 3.1.5. 8 bit with very little storage and even less memory is just not going to handle all the new stuff and the new new stuff coming down the pipes. Even the hawks are starting to be pressed.
