Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • is your x2 modified with a "resistor mod" by any chance?
          • No, none mod.
          • mine is not.
            in my opinion this 'mod' is very problematic as contact patch for soldering there is way too small for a mass of a typical non-integral resistor and it is just asking for a future trouble.
  • I flew with RC9 yesterday and have to say if is far more vibration resistant than RC8 was!
    I know my quad is not the greatest example, but as it has issues that show up readily it is a good example of the softwares tolerance to user over sight.
    Yes, I have ordered some of the HK orange foam and found that I have 2 motors with signifigant bell play, maybe the cause of the Z issues I have been having.
    I have been having problems with uncontrolled climb out when ever speed increases with with both 3.2 and 3.3r8.
    Yesterday with 3.3r9 I was able to fly as fast forward as the quad could go, right to the point of not having enough power to maintain altitude with out any uncontrolled climbing!
    The quad was flying well enough to run an auto mission which worked with out any noticeable issue.
    Loiter was better and alt hold also.
    Attached is a log of both and RC8 and RC9.
    2015-08-20 21-32-53 5.bin
    2015-08-12 17-13-06 9.bin
      Thanks Wes!!!
      That is great news!!!
      • 3702715983?profile=originalI think I found the smoking gun on my Z vibration issue. I had two motors with about 0.020 of bell play.
        I copied leonardthall's motor pin press and removed the play. The results were dramatic!
        The most improvement is seen in the RCO graphs.
        3702074297?profile=original3702715735?profile=originalVibe also shows improvement.
        3702716000?profile=original3702715876?profile=originalIMU is telling.3702716053?profile=original3702715895?profile=originalI read through the Arducopter pages and found no mention of bell play as a vibration problem. I think it would be worth while to add a note or two about it as the effect of play has a surprising impact on performance.
        RC9 was able to handle this level of Z vibration acceptable while RC8 could not.
        With the bell fix my quad is flying better than ever!
        • Sounds like invaluable information for the wiki. I'm looking forward to the good read.
        • Wes, I also had bad vibration issues on my 680 hexa and found just one of the motors to have a tiny bit of bell float /play. I used a vice and sockets to remove that play and as you have seen,  the vibes are now within execrable levels. I reported it here: http://diydrones.com/forum/topics/pid-help-required-video-example
          I agree on making it better known how bell play effects the vibes. Nice work on the clamp BTW!
          Congratulations Wes!!!
          I am sure that will be added to the Wiki. Your help here has been invaluable!!!
      • The log is has error messages all over the place, but actual flight performance was acceptable. RC9 is a nice step forward!
