Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • yes I have M8N and 6M, and the M8N is always lower HDOP , but i have had then switch in flight with no issue, seems to work ok for me in that regard and i have tested it too (by disconnecting the TX wire from GPS into Pix via a relay switch)....but i dont think the issue am having here is related to having 2 GPS necessarily...
  • Hi I have a quad done auto tune flies great with 3.3.1
    When in drift mode it can reach 50mph but is OK up to 30/35 mph but above that it starts to dive loosing height tried changing max angle for all flight modes to 30' but still losses hight above 35mph
    could this be software or does any one think frame/mechanic have reached its limit on forward speed and power to keep nose up enough to maintain hight
    It's not a barometer problem as I cover whole pixhawk in cling film to keep out wind altering pressure on barometer
    Stuart
      Hi stubugs,
      Can you provide a log please.
      • Hi did you manage to look at my log
        Stu
      • hi please find attached log
        many thanks stuart
        2015-11-08 13-28-14.tlog
        https://storage.ning.com/topology/rest/1.0/file/get/3702725746?profile=original
          Hi stubugs,
          Sorry, I need a data flash log.
        • Nice setup but it looks like you push the quad speed envelop to hard. Theoretical max propeller air speed with lowest measured bat voltage approx. 13.6V with 390kV motors and 5.5 inch prop is approx. 12.3m/s. To be able to move air faster increase voltage or change motors and propellers
          • Thanks I thought it might be on limits of the motor and props don't really want to go any more power or I'd loose flight time
            Stuart
        • My setup
          17x5.5inch props
          390kv motors
          30amp Simonk afro esc
          10000mah 4s
          Pixhawk 2.4.6
          Flys for half an hr
