Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Randy,
        here is one more log. I have tested RTL manually, I have tested RTL initiated by controller off.
        Both worked fine.
        Final RTL that should be triggered by battery voltage level never started. Here is the log. Could you please explain what is the deal? I did set voltage in the failsafe to 13.9V. I drained poor battery all the way down to 11v. Nothing happened.
        Am I the only one who experiences this? How can it be possible?
        3.zip
          Paul,
          Apologies again for the delay.  I had a quick look at the log and I don't immediately see why the battery failsafe didn't trigger.  I'll review the logs in more detail to more to figure it out.
          • I just made maiden flight on other drone using hex firmware. same thing - voltage goes down below failsafe setting but nothing happens. it is same avau x2 clone but I am not sure if it is hardware.
          • thanks. it looks like a bug to me as I tried all different possible combinations of parameters by now, including and excluding mah reserve percentage - this battery failsafe never triggers.
            • Might be worth flushing your firmware and reloading from scratch if not done already. I think there is a method to ensure a 'clean slate'.
            • Paul do you possibly have something connected to (supplying power to) USB port on the pixhawk?   Battery failsafe won't trigger if the USB is connected.
              • absolutely not. drone was in the air. standard telemetry was supplied from standard Serial1 telemetry port.
                can software confuse somehow Serial1 with USB port now?
                • A while back on APM controllers the stack would sometimes see the USB as connected even when it was not. Kev went so far as writing in a detection for this event in his Log Analyzer but I haven't seen this happen in months so whatever it was has probably been fixed.
        • Hi Paul,
          I can tell you for sure that this battery fail save is working, but I do have the mAH value filled in as well.
          So theoretically it should either trigger the failsave on a low voltage, or you have reached total capacity of the battery minus the set value (mAH failsave value)
          In the clip I uploaded, you can see it gets triggered around 14:27 see
          http://youtu.be/bwXqhHr-ieM
          This time it activates the land mode because I am very close to the takeoff location.
          If you are further away it will trigger an RTL, and for these reasons I have reserved battery Capacity (2000mAH), to be able to fly back, otherwise it may start dropping out of the sky somewhere out of reach...
          I however have never tried to fill in just the voltage..,
          Erik
          • it absolutely always worked with just voltage. what if I have multiple batteries of different capacity?
            all I care is that it is a 4S battery and at 13.9V I need to do RTL. It does not happen in 3.3rc5. And it was working in 3.2.
