Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
hi, I was 'lucky' to get it on my first attempt, if you look at vibrations log there is a spike close to 3min mark - it is where it dropped on ground as all controls went erratic and I then killed motors, prior to that trying to do RTL that did not do anything.
Pls advice if you will see anything in there.
I then tried 3 times - and got nothing. 'super simple' mode is attached to channel 11. 'simple' mode is on channel 10. I did not see any issue with 'simple' mode during this test and after first incident with super simple mode it then worked fine on 3 subsequent take offs, close and far.
1.BIN
Hi Pomaroli,
Nice!
Have you got some photos and specifications you an share with us?
Also,
could anybody explain nature and a reason of why in the 'super simple' flight mode all controls suddenly may flip/invert or even worse - 'turn' 90 degrees? What is causing this? As sometimes it does not happen at all but if it does - it 'locks' into this and only way to get rid of it then is to disarm the drone and arm it back on, simple mode switch does not help.
Paul,
Do you have a log? I had a peek back at a few of your post but don't immediately see it. It's possible there's a bug in the logic although it works in the simulator ok.
By the way, the vehicle must be at least 10m away from you or it won't update how the angles are applied. We can easily make that area smaller but the GPS accuracy becomes a problem if the vehicle is very close.
Randy,
here is one more log. I have tested RTL manually, I have tested RTL initiated by controller off.
Both worked fine.
Final RTL that should be triggered by battery voltage level never started. Here is the log. Could you please explain what is the deal? I did set voltage in the failsafe to 13.9V. I drained poor battery all the way down to 11v. Nothing happened.
Am I the only one who experiences this? How can it be possible?
3.zip
Paul,
Apologies again for the delay. I had a quick look at the log and I don't immediately see why the battery failsafe didn't trigger. I'll review the logs in more detail to more to figure it out.
I just made maiden flight on other drone using hex firmware. same thing - voltage goes down below failsafe setting but nothing happens. it is same avau x2 clone but I am not sure if it is hardware.
thanks. it looks like a bug to me as I tried all different possible combinations of parameters by now, including and excluding mah reserve percentage - this battery failsafe never triggers.
Might be worth flushing your firmware and reloading from scratch if not done already. I think there is a method to ensure a 'clean slate'.
Paul do you possibly have something connected to (supplying power to) USB port on the pixhawk? Battery failsafe won't trigger if the USB is connected.
333
334
335
336
337
of 449 Next
