Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I have two Pixhawk running arducopter with version 3.3.1 and one with
    3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
  • Wil there be ever oneshot support with pixhawk in the future?
    • +1 For that!
        It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
        • If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
          • This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
            • yes please, oneshot support and blheli 1wire update through copter software
              So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
              RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
              Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
              I for see a lot of questions
  • Hi,
     Do the latest firmwares support V and T setup for hexacopters at all?
    3702119253?profile=original
    • I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors).  It worked out OK.
      Duffy,
      I'm afraid we only support X and + for the Hexacopters.  It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
T-MOTOR liked T-MOTOR's profile
16 hours ago
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
