Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hello everyone,
@Shaun, this mistake is due to the inclusion of the variable "Timeus" to CAM messages and restructuring of the message CAM data. Note that the variable "Timeus" has been included in all messages, so the messages ATT and GPS are also affected. To fix this, simply adjust properly "offtsets" in the setup screen Geotag Mission Planner tool.
Your configuration is incorrect, with new releases, for ArduCopter, Mission Planner must be set like this:
I hope I've helped.
Regards from Spain,
Dario
I just performed a mapping flight and I'm having this exact same issue trying to geo-ref my images with 3.3-rc7.
Using AMSL Altitude True
Reading log for GPS Messages in order to get AMSL Altitude
Log file problem. Aborting....
I'm guessing it's because of the size of the log file with all the fast IMU logging enabled (80mb). Does anyone have a workaround? It's quite important to get these images geotagged!
Edit; I can see the CAM messages are in the log if I filter them out. Is there any way to export these into their own log or otherwise work with them?
Good to have these reports.
It's possible that it's because of the changes to the size of the time field. I've created an item here for the Mission Planner to investigate/fix this.
Thanks Randy. I've got Pix4d looking into making sure their software will works with 3.3 logs as well.
Pix4d says the kappa angle is 90 degrees off and that's causing the orientating problem with their software geotagging. CAM, 595372339, 339994200, 1854, 49.8042384, -119.4715983, 578.83, 69.99, 2.10, -9.35, 266.46. In my quality reports I get and RMS error on kappa at 89 degrees. Sure it won't be too difficult to fix : )
Thanks, let me know if you need any logs, but I would assume this is an easy one to recreate.
Is there a potential workaround in the mean time?
Trying to use photoscan, so hopefully there's a fix in MPs geo-ref tool soon!
I tried to manually pull the CAM lines from the rc7 log into their own file and format them the same as a 3.2 log, so that the tool would accept them, but didn't have any luck. There ended up being 300 CAM lines for the 170 images that were taken, so I'm not even sure what's going on there...
Thanks for the info. I ended up just using the .tlog off the tablet to tag the images with a time offset. Took a bit of trial and error to get the offset close to where it should have been, but was still not as accurate as using the CAM messages.
Glenn, assuming 3 things: that the GPX file and the JPEGs are in the same folder, that you are located in that folder with the command line tool (whether Mac or PC), and that the time in the images and the time in the log are in sync, then the ExifTool command is "exiftool -geotag NameOfFile.gpx *.JPG" (match the case of the extension of your images). You'll get a bunch of error messages, but they have no consequences (anyway, they did not for me). Sample check the exif info by looking into one of the images: you should see the five newly added GPS tags. If you need to deal with a timezone or other time difference between images and GPX, you'll need to use the Geosync tag in the exiftool command: find out more about that here: http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html. I hope this helps. Let me know. Fred
Yes please Fred, do you mind posting the exiftool command you used? Also if there are any other steps to get the tags into the images that info would be appreciated!
I have created the KMZ + GPX from the log, and have exiftool.exe and the gpx in the folder of the images to geotag.
