Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • will double check, when I come home, thanks.
          Hi Dave,
          I am looking at the correct log but it doesn't show any yaw spinning. I am pretty sure you have uploaded the wrong log.
        • The log where the pictures are from is from your first post. Perhaps you can post the crash log again? I can´t download the log from the second post.
    • since your running 530kv motors with simonk firmware esc the sync issue is very possible. That spin was like I have never seen before. I would highly doubt that any SW issues such as EKF would cause that type of spin. Highly doubt it.  If it was a flyaway maybe even a high pitch or roll uncontrolled but that spin no way.
      • how can I reproduce this type of error?
        would you recommend BLHeli then?
        I first want to find out the issue of the crash before changing anything.
        • First I highly,highly recommend BLHeli for those motors. Second yes you can recreate it if its an issue but not sure how since I have never had that problem and have always been using BLHeli  Never had to search it but I have heard that you can recreate it. You can also improve it by lowering the PWM frequency I believe with RC_SPEED parameter or something similar. If I were you I would flash BLHeli and that way you have nothing to lose really. And do more tests with props upside down.
          If it is a sync issue I am not sure how you can actually find that out from logs. Since its from ESC onward and pixhawk does not have visibility there as far as I am concerned.
          • ok, thank you very much for the information.
            I will now first try to recreate the issue by full throttle individual motor tests, let's see how that ends..
            • I´m quite sure there is no problem with your esc. While the coopter descends all RCOUT channels are close to each other
              3702887768?profile=original
              and the copter doesn´t flip. It follows the desired attitude quite well:
              3702887785?profile=original
              I think there is something wrong with the IMU of your AUAV. In the ATT readings there is no sign of the spinning we can see in the video. Looks like the FC tried to compensate a wrong detected spin from the IMU:
              3702887972?profile=original
              • I agree with you but regarding the first part of your answer, I thought the following:
                If there were sync issues, you can't see them in the log data. The ESC just fails and the motor stops, or am I wrong?
                Will check the IMU when I come home. Thanks!
                • thanks guys.
                  yeah, you can just see the spinning when you click "Show Map":
                  3702929421?profile=original
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
