Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • since RC3.2 release the pixhawk has become more sensitive to vibrations (for better filtering). it is very important to have tuned foam pads which are only available form 3DR. what is important is the damping effective of foam when pressed and released. they may look to be same but 3DR has tested the foam on vibration machine (I think so). I had a problem of vibrations when I upgraded form 3.1.5 to 3.2. by changing to 3DR foam the issue got resolved. also the FC should not be touching any part of the frame. and most simple and important step is to balance the props.
    • Don't this this is a pad-type trouble for my case. This is *constant* spikes, do not depend on throttle, movement speed.
      Ravi,
      Thanks for the input.  I also recommend the 3M foam that 3DR sells.  Paul Riseborough thinks the HobbyKing ping foam (sorry I don't have a link) may be even better but it's not sticky on both sides so it's a bit more trouble to use.
      We really don't think that copter should be more sensitive to vibration between AC3.1.5, AC3.2 and AC3.3.  We're attempting to make it less sensitive to vibration by increasing the accelerometer range from 8g to 16g, improving the fitering, increasing the read rate from the accelerometers, etc so I really hope that's it's not getting more sensitive.
      If you really think it's more sensitive we'd like to see a log.  I know it's hard to prove it's more sensitive, it probably requires using a borderline vehicle and running back-to-back tests that show bad behaviour on the new firmware but not on the older.  I know it's a big ask but I've never seen such a test done.
      • Sorry for my ignorance, but I just bought Zeal pads for my Pixhawk, and it seems, reading posts here, that Zeal isn't anymore the recommended solution.
        Why is that?
        I had almost no vibration with them on my other APM2 quad.
          Igor,
          I think Zeal pads are probably ok as well.  I haven't used them personally but I've heard some good things.
          • Can you have over damped solution? I have $_12.JPGand zeal under it and flight controller attach with hobbyking Flight Controller Mounting Pad
  • From logs, I see what only IMU1 has such spikes. IMU2 looks better. Where is IMU1 and 2 placed? One on Pixhawk, and second?
  • Fair enough. Could you elaborate or point me to how you identified jamming? I could then see what makes it improve. Thanks again.
  • I did, but moved hardware to another frame, so can't use it twice. Anyway, this is not pads, because I did several tests with different pads, and always get same results.
    • Ok, tested same frame/hardware with 3.2.1. Did clean install - apply defaults, apply my custom settings, calibrate RC, compass, accelerator. And did flights.
      3702880071?profile=originalBut, I had an accident at the middle of the flight ... investigating ...
      2015-05-05 16-57-05.bin
