Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                • Randy, do you know, is it normal?
    • elevate your compass as much as possible, than run compasmot.
      • Compassmot almost at zero. Also, do not see any problems on flying. On one copter I had a very huge compassmot results, and I even can't fly without errors (and landing as failsafe). Here, I do not see any troubles while flying.
  • Is the issue with AUAV-X2 fixed?
      Darn.  It's suppose to be fixed.  So what we may have here is a failure of the fix and the dev testing of the fix.
      I don't have a board myself but we will review the patch and see if we can spot the error.  A few people on the dev team have AUAV-X2 boards so we should be able to test and include in -rc9 and/or a patched -rc8 so you can test.
      Thanks for the report!
      • Randy,
        i made a short test with my AUAV-X2 and -rc8:
        LogWhenDisarmed = ENABLED
        When powered over USB the log gives a 5 on Powr/Flags.
        When powered with battery the log gives a 7 on Powr/Flags.
        That means, the Bit for USB_CONNECTED is always 1.
        It seems, the problem is NOT solved...
      • Ok, let me know if i can try to recompile or patch this code and try it out, i may have time for that next week.
        I still saw same compass variance error trying to "fly by hand" with rc8. Also note hdop 0 issue - but, even with it, little drone behaved way better now than with rc7.
    • T3
      Hi DG,
      the issue seems to be solved.
      Cheers,
      Thorsten
      • OK, it does not seem to be so.
        is the 'Connected=True' message in the MP status window referring to USB connection specifically?
        mine is not connected to USB and it stays as 'true'.
        What is expected from
        return stm32_gpioread(GPIO_OTGFS_VBUS) && stat("/dev/ttyACM0", &st) == 0;
        this to happen? what is the 'stat("/dev/ttyACM0",'? Does it need any hardware modification on the AUAV board or not?
        • if it matters or no, here are start messages from MP, below. Was it expected to identify AUAV in there somehow?
          APM:Copter V3.3-rc8 (818ef282)
          PX4: b0cb142b NuttX: d447403a
          Frame: QUAD
          PX4v2 0025002A 3333470F 39323135
          PreArm: Need 3D Fix
